460- Oil pressure Sender
I have a 460 from a Grand Marquis, I think around 1976. Wondering where the oil pressure sender is. I can't remember from when I was cleaning/installing it. I took a quick look, but it could easily be hidden. Is it on the back of the engine?
I have a oil filter relocator on it. Couldn't I just run a hose from the guage straight into one of the available holes in the relocator plate?
Thanks.
Thanks.
I had my pressure sensor up by the oil pump and it was about 5psi higher than at the rear. I moved it to the rear because this is the last and furthest away from the oil pump. Just starting my engine today when it was -16 the oil pressure hung around 0 for about 3-4 seconds and took about a minute to get up to about 50psi. The normal cold psi on my 460 is 80psi so I know there wasnt much flow going on.
SVTDriver97
06-10-2014 06:21 PM
racerc2000
01-06-2013 02:07 PM
Andy63
07-20-2002 07:38 PM
