Oil pressure sender location?
06-10-2014, 10:56 AM
Where is the oil pressure sender located on a 1986 F250 460?
06-10-2014, 10:59 AM
It is at the back of the intake maniold (between intake man. and bellhousing) on the top of engine.
06-10-2014, 11:01 AM
on
Yup, standard location on Ford V8 engines it seems. My 335 series all had it there. It's a good spot considering the limited real estate on engines.
06-10-2014, 11:17 AM
Does anyone have a picture of it? Like what it looks like?
06-10-2014, 11:36 AM
on
Location listed is correct. Here is a picture, with several things removed so you can see it. I outlined the sender in yellow and the riser off the block in red. Crawl up in there... you'll see it buried down there.
-BlueBruiser
06-10-2014, 12:15 PM
Quote:
Originally Posted by
RL250
A lot of the 302's and 351w's had it down low on the driver's side front corner of the engine, near the oil filter and the fuel pump.
06-10-2014, 12:24 PM
That's great, thank you very much guys!!
06-10-2014, 12:56 PM
on
Franklin2
Thanks, didn't know that. I never really looked for it when I had my 302 powered F150 and Bronco. Not that the Bronco would have been correct.
06-10-2014, 06:21 PM
Franklin2
All Windsor blocks, as far as I know.
335 and 385 series are the only ones I know of that have it in the rear upper portion of the block. Even the old FE series had down by the oil filter.
Ranger92
06-13-2010 11:00 PM
79 Camper Special
11-08-2007 11:54 AM
inline6 Red Neck
06-05-2006 05:20 PM
66MercMan
01-22-2004 02:17 PM
stsrus
07-27-2003 11:57 PM
