Offroad & 4x4
welding spiders
Old Jan 20, 2004 | 06:02 PM
kopfenjager's Avatar
kopfenjager
Question welding spiders
I'm considering welding my front dana44 spider gears. Has anyone done this. I've heard of a few ways of of welding them up. I realy would like to hear from someone who has done it. Thanx
Old Jan 20, 2004 | 07:57 PM
JeremyH's Avatar
JeremyH
Say "bye bye" to turning.
Old Jan 20, 2004 | 08:36 PM
93_F150's Avatar
93_F150
I did it on mine... but I only recomend it on auto hub trucks, because tight turns are hell on the front end (not to mention the guy holding the steering wheel) I always back up and unlock the hubs before making a tight turn. If I need 4wd to make the turn, they there's enough slippage to keep from exploding the front end
Old Jan 20, 2004 | 09:31 PM
peppy's Avatar
peppy
Sounds scary to me. I think I'd save my pennies and invest in an airlocker. Oops, I am saving my pennies for an airlocker, or two.
The good part is you only need around 90,000 pennies, plus tax. Each.
Old Jan 20, 2004 | 09:33 PM
fishmanndotcom's Avatar
fishmanndotcom
i completely and totally disagree with 93_150....manual hubs are the way to go....that way you can keep one hub locked and retain a lil bit of turning radius and when it gets hairy lock the other side in.
I have some pics of a 10.25" welded rear if ya want them, they aren't much different! I am about to do it to my D60 front. Talk to 85351Ho.....his is done this way!
strong....cheap....reliable (if done right)
-Jason-
Old Jan 20, 2004 | 09:37 PM
JeremyH's Avatar
JeremyH
A box of welding rods only costs $50!
Old Jan 20, 2004 | 09:39 PM
fishmanndotcom
geez....where you getting rods from? 7018 in a 10lb sealed box around here is like $8.99
-jason-
Old Jan 20, 2004 | 09:41 PM
BroncoRoadKill's Avatar
BroncoRoadKill
It's called a "lincoln locker". And doing that, you could risk destroying your carrier, ring gear, and or housing.
Old Jan 20, 2004 | 10:07 PM
fishmanndotcom
i agree...but if you do it right it will serve many many years. It's the ppl who tack weld the spider gears to the carrier that i am really concerned about!
-jason-
Old Jan 20, 2004 | 10:30 PM
JeremyH's Avatar
JeremyH
-jason-
50lb boxes
Old Jan 20, 2004 | 11:41 PM
fishmanndotcom
10-4
-jason-
Old Jan 20, 2004 | 11:50 PM
BlueOvalboy25's Avatar
BlueOvalboy25
no steering good in the mud. i did it on my 1980 gmc 4x4 and it is like night and day it chews like mad. but trying to turn sucks.
Old Jan 21, 2004 | 03:17 AM
kopfenjager
Yeah, I hear ya. Turning is going to suck, but it should crawl straight threw anything. I heard of welding the spiders to the case and I have heard of complete disassembly and welding in the valleys of the spider gear to bind them up. I have also heard of guys pouring lead into there carriers to stop the spiders from working. I gues my question realy is what is the best way to weld my spiders?
Old Jan 21, 2004 | 06:20 AM
fishmanndotcom
weld the spiders together by filling in the teeth. then weld the spiders to the carrier. Make sure you DO NOT get any slag in the axle splines....put cloth or something in there.
-jason-
Old Jan 21, 2004 | 10:23 AM
KJKozak2's Avatar
KJKozak2
You could save yourself some hassles and maybe even some money if you put a mini-spool in there. It does the same thing but it's reversible. There's also less of a chance of it coming loose.
I haven't checked on availability or price for the dana 44, but the one I have in my 9" was $28 on ebay (including shipping).
Just a thought.
Kevin K.
