Test Generator / VR w/ Multimeter?
Old Jan 19, 2004 | 10:50 PM
MercM47's Avatar
MercM47
Is there anyway to Test Generator & Voltage Regulator w/ a multimeter?
Not getting a charge, swaped the gen & vr and still the same. Is there a way to identify which is not working?
thanks
Old Jan 20, 2004 | 08:54 AM
mtflat's Avatar
mtflat
Just a couple of things to consider-
1. Did you remember to polarize the generator after it was unhooked?
2. A generator doesn't put out current at idle speed. Run the engine about 1500 rpms and check with the multimeter.
I just use a continuity tester but a multimeter should work.
Old Jan 20, 2004 | 09:14 AM
MercM47's Avatar
MercM47
Polarize the generator? How do I do that? Its a 12v Generator & Votlage Regulator.
Thanks!
Old Jan 20, 2004 | 12:26 PM
mtflat's Avatar
mtflat
With the battery connected, engine off - disconnect the wire from the field terminal of the regulator and momentarily touch the field wire to the battery terminal of the regulator. Normally you'll see a small blue spark. Reconnect the field wire to the field terminal.
I know it sounds too simple, but if you don't do this when you have the electricals apart the gennie may not charge. 12 or 6V doesn't matter.
There is a 2 page explanation in the shop manual on how to check the output of gen and reg with a volt meter.
Old Jan 20, 2004 | 06:30 PM
MercM47's Avatar
MercM47
amazing how different the gennie sounds when polerized!
*blush*
Tedster9
Feb 12, 2014 05:14 AM
hairyboxnoogle
37
Dec 18, 2010 05:50 PM
darinbrooks
Nov 3, 2010 08:18 PM
1950ford
Sep 28, 2007 01:00 AM
FordPickup460
Nov 7, 2006 05:59 PM
