o2 Sensor Replacement
Old Jan 19, 2004 | 08:53 PM
acerockola77's Avatar
acerockola77
I've helped replaced an O2 sensor in my buddy's truck before and it wasn't too bad, and I figure since I'm getting terrible gas mileage for the gears I have. I'm getting about 13 mpg with 2.73 which is BS. I have a 102 K on my truck and it dosen't look like its been replaced, so I figure it's time to replace it, so here's my questions.
What size of wrench should I remove it with?
Where's the best place to pick them up?
How do you tell if the truck is running lean or rich?
Thanks Guys
Old Jan 19, 2004 | 09:40 PM
carpe_diem's Avatar
carpe_diem
I have replaced them several times --- but never on Fords. (I am getting ready too, however)
My Chebby experience. Typically, you need 7/8" deep socket. Auto parts stores sell these special O2 sensor sockets -- forget them, they are junk. You will bend it. (At least I did)
Then need PB Blaster. Soak it overnight. I almost gave up without it, man it was tight.
Then need a 1/2" Breaker bar.
Cut the wire, fit the deep socket over it, and break it loose, then use a ratchet to finish the job. With the new one, use a open end wrench.
And,
I would not use after market sensors for anything!!!! I had a terrible exprerience with after market junk. Use only OEM. I cannot emphasize that strongly enough. Saving 5 'dollars' is not a good idea.
They seem to have OEM parts:
http://www.ford-auto-parts-dealer.com/
Old Jan 19, 2004 | 09:56 PM
acerockola77
Thanks for the info carpe -
I was checking out this site: http://oxygensensors.com/ they claim that they are OEM, but the prices are incredbily low compared to anything I've seen aftermarket, so I'm not quite sure what to get, and ford-auto-parts-dealer didn't have one for the 4.9L.
Old Jan 19, 2004 | 10:37 PM
carpe_diem's Avatar
carpe_diem
On the aforementioned site, mine was quoted at $40. The last one I got for my chebby was around $29, also OEM of course. Bosch is not OEM as far as I know, and it is marginally cheaper, and I hear not as good.
I could change mine, only if I could find it. I need to get my truck on ramps.
P.S. 7/8" deep socket approximates to 22mm deep socket. That will work just the same if you have metric imports.
Whoops, another PS. Use anti-seize lubricant on the threads. I don't know how effective it is, but try it. I think it comes with the sensor. The sensor will have some on the threads already. and claim that it is not necessary. Just don't get any of that anti-seize stuff on the actual sensor, or it will damage it.
Old Jan 19, 2004 | 11:10 PM
EPNCSU2006's Avatar
EPNCSU2006
^ another thing about the anti-seize: be sure it is for O2 sensors, there is a difference. If it comes with the sensor, then it is ok. I've always been able to get mine out with a 7/8" box end wrench. It will just barely slip over the electrical connector.
Old Jan 20, 2004 | 12:23 AM
quaddriver's Avatar
quaddriver
And,
use a proper socket or a crescent wrench from hell.
btw, bosch is OEM for both ford and GM, both outsource this part.
Necromancer
May 7, 2014 11:23 AM
thefordguy
1997 - 2003 F150
Oct 14, 2010 10:16 AM
charlie00tj
Bronco II
Jul 16, 2010 05:22 PM
Schwinn240
13
Mar 25, 2010 06:57 PM
