Hinges?
Old Jan 19, 2004 | 03:59 PM
wickymustang's Avatar
wickymustang
Hinges?
I have a 1995 F150 regular cab pick up. My question is when I open my driver's door it opens maybe 1/4 of the way, then drops about 1-2 inches and opens the rest. Closing I have to open the window, and lift up then pull closed, any ideas how to fix?
Old Jan 19, 2004 | 06:51 PM
Greg 79 f150's Avatar
Greg 79 f150
Closely inspect the hinge action while someone opens the door slowly. You will see the hinge drop, most of the time its the pin worn, sometimes it wears a oval hole in the hinge, either will cause the door to drop. I replaced my 79's hinges, easier than doing the pin thing. p.s you will need to look at the strike pin also where the door latches on to, for adjustment also, if you change hinges, good luck
Old Jan 19, 2004 | 06:56 PM
marc9000's Avatar
marc9000
One or two inches? Might be a rust problem. A junkyard door (or new generic) may be the answer.
marc
Old Jan 19, 2004 | 07:08 PM
Greg 79 f150
marc
Hold on there Marc !, the guy said a 95 F150, not a 95 Chebby, ha, just Kiddin, see ya,
Old Jan 19, 2004 | 07:51 PM
wickymustang
No rust anywhere on this truck, not even surface rust, everything is clean.
Old Jan 20, 2004 | 10:48 AM
shortyforty's Avatar
shortyforty
Same thing happened on my wife's 94 GMC JIMMY. The door would drop a couple inches when opened. It turned out the top hinge pin had worked its way out of one of the holes in the hinge.
Had to pound it back in then center punch the end so it wouldn't slide out again. Seems to still be working.
Funke1
Nov 24, 2014 11:12 AM
429CJ-3X2
Aerostar
Feb 13, 2011 09:57 PM
2pd519
Garage & Workshop
Apr 14, 2009 06:43 PM
neilc88
Dec 8, 2007 11:55 PM
Heavenword1
Aerostar
Jan 31, 2007 11:36 AM
