Aerostar Ford Aerostar
Radiator fill tip
Old Feb 8, 2011 | 03:14 PM
429CJ-3X2's Avatar
429CJ-3X2
Radiator fill tip
In my cooling system trials lately, I have been using a Gatorade bottle with the bottom cut off as a funnel when filling the radiator. The top of the bottle fits snuggly in the top of the radiator. It's not completely watertight, but it's close. That 3 1/2 - 4" opening is a lot easier to hit than the radiator opening. It also serves as an overflow when the thermostat opens up with the rad cap off. It mostly blocks the overflow outlet, so all the coolant goes right back into the radiator.
Old Feb 8, 2011 | 05:30 PM
Car Guy's Avatar
Car Guy
I used the same Gatorade bottle for years before buying this, well worth $25......
Amazon.com: Lisle 24610 Spill-Free Funnel: Automotive
Old Feb 9, 2011 | 06:57 AM
96_4wdr's Avatar
96_4wdr
park with nose up hill and higher than back end by at least 2 feet.
run engine to let the air pockets work themselves out. may take 30 minutes or more revving engine. heaters on full blast for circulation
the 4L especially has poor circulation to the back of the block and the heater cores
Old Feb 13, 2011 | 09:57 PM
fishheds's Avatar
fishheds
On the topic of burping,I recently put in a new heater core.After a 25 mi commute,I hear a thumping sound coming from the thermostat area.Sounds almost like the T-stat slamming shut. .I can't tell if it does it at highway speed for the road noise.Everything else is good, temp stays betwee N-R,no loss of coolant anywhere,decent heat. Would air in the system cause this?
FWIW, after an hour of unsuccessfully trying to disconnect the q/d heater hose fittings,I finally twisted the core back and forth til the necks snapped off,pulled em back out through the firewall,put the new core in,slid the hoses back down the "spaghetti box" and pushed til I heard that oh so satisfying click.
FWIW II,my downshifting at highway speed problem was cured by a nused
gauge cluster.Your results may vary.
txuhaul
22
Dec 22, 2016 10:31 PM
zjmj17
Dec 10, 2016 05:01 PM
KJNDIVER
61
Jun 2, 2016 08:33 AM
ssandirene
Feb 24, 2016 04:27 PM
CowboyBilly9Mile
Dec 4, 2004 04:12 PM
