Here's what I pulled up.Not for sure if it's correct or not though...
- 95 (O) Fuel pump: open, bad ground or always on - Power / Fuel Pump Circuits
(R) AIR not Diverting (AIRD) - Air Injection
(M) Possible bad fuel pump ground or open between fuel pump and pin 8 at PCM (Fuel Pump Monitor signal) - Power / Fuel Pump Circuits
cranks no start driving down the road quit running changed broken crank sensor can hear fuel pump running but no spark or fuel to motor getting code 95 make any sense crank sensor got broke from a rock.
