1978 - 1996 Big Bronco
error code 624
Old Oct 6, 2006 | 02:21 PM
gnuiver's Avatar
gnuiver
Question error code 624
My 95 ford Bronco Is showing a code 624. (351 Auto, 4x4)
Old Oct 6, 2006 | 03:56 PM
greystreak92's Avatar
greystreak92
EPC (Electronic Pressure Control) solenoid failure or failure of the circuit is the fault causing code 624 to show up. The 600 series codes are E4OD transmission-related fault codes.
Old May 13, 2007 | 02:47 PM
ryancross's Avatar
ryancross
I have a 91 F150 with a 302 and the E4OD. The code is still coming up as 624. I have put in a brand new uprgraded Solenoid pack. This thing shifts sooooo hard still! What could be problem be. Taken it to four tranny guys and they say it is a voltage problem and the lines are running at full pressure. Are there any fuses, circuits, connectors to check. Everything appears to be hooked up properly.
Old May 24, 2021 | 04:40 PM
mitchsens's Avatar
mitchsens
did you ever figure out the issue
Old May 24, 2021 | 07:13 PM
torq'ta 5 8's Avatar
torq'ta 5 8
How did you get the code 624?
KOEO = "Key On Engine Off" during the EEC-IV quick test, it would be wiring or bad solenoid.
After this test gets done then the computer will put out the CM codes.
CM = "Continuous Memory" is the problems that the computer has seen while driving.
Est1991
Aug 23, 2023 12:20 PM
rvE350_1994
Jun 22, 2018 07:40 AM
rwpearson
May 23, 2017 02:28 PM
Beau109
Jun 12, 2015 06:00 PM
