Cam position sensor
Old Jan 18, 2004 | 11:13 AM
Code 5 Ford's Avatar
Code 5 Ford
Cam position sensor
I have heard people talk about faulty cam position sensors. When they go bad your tach wont move when cranking. This is the way you tell if its bad-- at least thats what I have heard. I own a 2002 F-350 PSD, CC, 4x4 with 26000 miles. The other day I decided to check if my tach moves when cranking. I does not. My truck runs fine and have had no problems with it. Does this mean my cam position sensor is bad? I dont think so........ So why the theroy of bad CPS=no tach reading when cranking. Does this only apply to certain years?
Old Jan 18, 2004 | 11:54 AM
grizz_chaser's Avatar
grizz_chaser
I'm interrested in this also. Going by the tach doesn't move theory, cost me a $100 just to learn the tach doesn't move and the CPS was fine.
Old Jan 18, 2004 | 11:56 AM
F0rdF0rever's Avatar
F0rdF0rever
I noticed the same thing on my 95. No tach movement while cranking. But cam sensor is fine.
Old Jan 18, 2004 | 08:52 PM
mybigredford's Avatar
mybigredford
i will check my tach next time i start it and tell you what i find.
Old Jan 18, 2004 | 09:48 PM
Austin Charles's Avatar
Austin Charles
Mine just went out last week.
I had to get towed.
Mine would start, run for 30-40 sec. and die.
Never watched the tach, to pissed to see staight.
they say $200.00 for the dealer or $100.00 to do yourself
My engine has a 100,000 warranty- cost me $100.00 deductible
Old Jan 18, 2004 | 10:24 PM
bigstroker's Avatar
bigstroker
I just had mine go out last week, and the tach would move a little while cranking, but i replaced the cam sensor and alls well.
Old Jan 20, 2004 | 02:01 PM
1necowboy's Avatar
1necowboy
You will know when your cam position sensor goes out , cause you will go no where, when it dies rpms drop to nada and will not show until you replace it , or it starts in a few minutes or hours.
Iam no expert but just replaced mine via suggestions here.
Old Jan 20, 2004 | 05:19 PM
mybigredford
hey guys i watched my tach yesterday, and it didnt move either, and my truck runs great. just thought i would report back cause i said i would.
later
Old May 9, 2004 | 08:10 PM
micviking's Avatar
micviking
Hello is the cam position sensor under warranty. Mine is a 2001 with 45,000. The mechanic told me mine is about to go out. He hooked it up to the computer.
Old May 9, 2004 | 08:18 PM
johnsdiesel's Avatar
johnsdiesel
Yes, it's covered under warranty but you'll have to pay the deductable.
Old May 9, 2004 | 10:26 PM
wlihntr's Avatar
wlihntr
my truck runs fine, had the CMP(CaM Position sensor, "i guess") replaced a few months ago because the truck would just die. to this day the tach does not move when cranking the motor.
