1978 - 1996 Big Bronco
spare tire question
Old Jan 18, 2004 | 08:07 AM
MHowell's Avatar
MHowell
spare tire question
Why are some tires located on the tailgate and some on the inside. My 90 xlt has it mounted in the cargo area inside the truck. Just curious why ford did that.
thanks Mike
Old Jan 18, 2004 | 08:08 AM
BillyBob69's Avatar
BillyBob69
Options?
Old Jan 18, 2004 | 01:13 PM
BigRedBronc's Avatar
BigRedBronc
Hmmmm...
Mounting on inside takes away storage from owner, is inconvenient, and most importantly...is very cheap.
Mounting carrier on outside frees up cargo area, is more convenient, and costs more money.
Car companies pass the cost to you by calling it....
Drum roll please...
a factory option.
BTW, you can buy one in aftermarket for about $120. Buy one in a junkyard (if you can find one) for about $50.
Good Luck.
Old Jan 18, 2004 | 07:01 PM
Black Ford XLT's Avatar
Black Ford XLT
spare tire carrier
Back in the 80s i saw a cool looking thing ,spare tire must of been mounted inside with the rack sporting a grill made to fit the spare tire carrier--slide the carrier open cook steaks .TR
Old Jan 18, 2004 | 07:15 PM
BigRedBronc
Very cool. I am not to sure about having a cookout that close to a 25 gallon gas tank though. Might turn out the steaks aren't the only things getting cooked.
Old Jan 18, 2004 | 08:12 PM
ANdrewdrice's Avatar
ANdrewdrice
if you run a fule line to your grill, you can use gasoline to cook with also, no extra propane or charcole. might be detrimental to your gas mileage.
Old Jan 18, 2004 | 08:30 PM
treehugger36's Avatar
treehugger36
25 gallon tank?! I thought mine was a good bit bigger than that! Its an 89... isnt it closer to 32?
I may be way off
McNabb
Old Jan 18, 2004 | 09:41 PM
flyer105's Avatar
flyer105
I have a 96 EB and it has a 32 gallon tank. As far as the tire carrier...I had a K5 with the inside tire and it came loose during a late night offroad run and hit the rear seat passengers! No damage done just more laughs than anything else. My Bronco has it on the outside and that is where I like it.
trevorrules
15
Nov 6, 2015 12:38 PM
Icefan71
Jan 23, 2010 03:03 PM
triton54
Offroad & 4x4
Oct 10, 2007 07:09 AM
ajm859830
Feb 19, 2007 11:35 AM
Pilotrick
19
Aug 30, 2002 04:15 PM
