429 parts
Old Jan 17, 2004 | 06:30 PM
RichardMaerz69's Avatar
RichardMaerz69
429 parts
having troubles finding parts for 429 ,what engine mounts other than a 460 will work on 429? I also need exhaust manifolds.460,429 engines are hard to find around here,it's going into a 75 half ton,thanx.
Old Jan 17, 2004 | 06:42 PM
greenhighboy's Avatar
greenhighboy
Check e-bay. There are always manifolds on there and I have saw alot of motor mounts on there for 2-wheel drives with 460's. 3/4 ton mounts will also work. Do a search for 460 in e-bay motors.
Dennis
1999 F-350 Powerstroke
1977 Highboy 429 4-speed 35"s
1972 Ranger on a 1978 F-250 4x4
frame 466 Pulling Truck
Old Jan 17, 2004 | 07:09 PM
bubbasz1's Avatar
bubbasz1
Check out L&L products, they have everything you want to put a 429/460 in a truck.
http://www.landlproducts.com/
Old Jan 17, 2004 | 08:04 PM
wdfp's Avatar
wdfp
I may have what you need, if the exhaust manifolds from a 70 t-bird will work, they are already off, and the manifolds from my 77 F-150 2wd should be coming off within a week or two at most,(replacing the engine) if the 70's will not work. So if you need them, let me know and we will figure out how to get them to you. dan
Old Jan 17, 2004 | 09:27 PM
Breeze's Avatar
Breeze
Enging Mounts 429 and 460 interchange. (altho there is the old trick of rotating a set of 390 Mounts 45 degrees and using only 2 bolts into the block ****NOT RECOMENDED***)
Exhuast: If its a 2wd, you should have no problems getting headers for it at a reasonable price. If you really just have to have the manifolds, try to use truck manifolds if at all possible, otherwise you will have to notch the right frame rail if you use car manifolds. Van manifolds will also work.
http://www.lmctruck.com/ has free catalogs with most anything you will need for your truck, including new manifolds if you want. Altho the EGR manifolds are pretty salty!!
Old Jan 17, 2004 | 11:13 PM
There Goes The Neighborhood's Avatar
Breeze, you dont have to rotate 45 degrees and use only two bolts. Get a set of mounts for a 390 in a '66 Ranchero, slot the holes(all three) and elongate the holes in your mount stands. This works great, and sets the motor about 4 inches lower than custom or L&L mounts. They also cushion the tourque better than solid mounts.
Just my $.02.
Also, IMHO, L&L is overated and overpriced. Hooker makes better headers(as do Hedman, and others), and oil pans are cheaper through FRPP. Okay, I'm done ranting now.
Old Jan 18, 2004 | 02:50 PM
Breeze's Avatar
Breeze
Actually the days of playing with the FE mounts are long over, I bought the proper conversion mounts I guess about 10 yrs ago (still running the ones I bought), and have had no problem with them since
Old Jan 18, 2004 | 03:03 PM
bubbasz1's Avatar
bubbasz1
RichardMaerz69
No matter which way you go, read first, ask like you did today. When I put my 429 in my bronco 15 years ago I choose L&L. Now if you go with Hooker, unless they have changed things you need to use a certain motor mount. L&L gives you the ability to get everything plus lots of other things from one place and they will all fit. Belive it or not You have many options and it can get confusing so take your time and do your research, cause the worst thing is to start putting something together and the goodies don't fit.
Old Jan 18, 2004 | 09:10 PM
tess100's Avatar
tess100
ever make it to brooks ? i have manifolds for you all you need to do is pick them up
bertha66
Apr 26, 2010 01:31 PM
7mpg302
Dec 3, 2008 06:17 PM
Jrock909
Jan 29, 2007 12:26 AM
husker11
Mar 4, 2004 09:38 AM
phantom429
Jul 7, 2002 04:36 PM
