Old Apr 20, 2010 | 10:53 AM
bertha66's Avatar
bertha66
429/460
I just picked up a 76 F250 4x4 with what the PO said was a 429, he thought it was a 79 429 car engine, sense Ford did not make a 429 car engine after 73, I'm thinking 460. What is the stroke for these engines or where is the ID numbers on the engine so I can decode what it is?
Old Apr 20, 2010 | 07:25 PM
monsterbaby's Avatar
monsterbaby
stroke is 429 = 3.59" 460 = 3.85"
Block casting number is right above the starter. BUT 429 and 460 use the same block. IF it's a D9TE-AB casting then it is NOT a 429 car motor (the 429 Lima truck engines did use that block though)
Old Apr 21, 2010 | 12:02 AM
71cc's Avatar
71cc
If it is easy to remove the oil pan, I would check the casting number on the crank. You would know for sure what stroke it has.
Old Apr 21, 2010 | 11:39 AM
bertha66's Avatar
bertha66
I will be removing the pan this weekend for a oil pump change, so what casting # am I looking for?
Old Apr 21, 2010 | 12:25 PM
71cc's Avatar
71cc
CID Year Crank Casting Number
429 '68-'78 :4U, 4UA
460 '68-'78 :2Y, 2YA, 2YAB, 2YABC
460 '79-up :3Y
Also be aware there were two different pilot diameters for torque converter in the early years. This is something to verify now. You don't want to get the build done and find out your new combination fits loosely,or not at all.
Last edited by 71cc; Apr 21, 2010 at 12:35 PM. Reason: converter or pilot problems
Old Apr 21, 2010 | 02:59 PM
bertha66's Avatar
bertha66
460 '79-up :3Y
Thanks alot, The engine is in a 76 F250 4x4 with a 4sp.
Old Apr 21, 2010 | 06:13 PM
monsterbaby
That info is not needed for id of the engine though (no 429s in light duty trucks at all, and no 460s in 4x4s until the 80s)
But it is a nice swap.
Old Apr 22, 2010 | 11:58 AM
bertha66's Avatar
bertha66
Yes, it is not infro need for the ID, but as 71cc said something about pilot diameters, I thought that I would though out there that the engine is allready in a running truck and I was not building a engine for a fresh swap. I have rebuilt one 385 engine before, I have a 460 in a 80 Bronco, but I spent most of my time on FE engines, so the 385 is pretty much a unknown to me.
Old Apr 26, 2010 | 01:31 PM
bertha66's Avatar
bertha66
I had the pan out this week end, to only mark that I could find was a "3", no "Y" on it. Did not get the stroke checked.
79MudRat!
Nov 12, 2012 07:28 PM
Jrock909
Jan 29, 2007 12:26 AM
76JDGREEN
Engine Swaps
Aug 23, 2006 09:26 PM
dino
21
Dec 18, 2005 10:30 PM
53flathead
27
Oct 1, 2004 07:41 AM
