Jan Flash
Old Jan 23, 2004 | 09:55 AM
  #31
SPFDRum's Avatar
SPFDRum
Try 1-313-322-3000 press 0 then 0 again to get an operator, ask for someone in Customer Assurance Department. I talked to Blaine, but others have had good luck with a Duncan. My concern was the removing of tranny braking in 4th and 5th, as I haul my tractors, that is a safety issue, and that's how I expressed it. They do seem genuine and I felt good about the call when I was done.
Old Jan 23, 2004 | 04:55 PM
  #32
powerstrokedieselboy's Avatar
DON'T LET THEM FALSH IT WIT THE NEW....
I got a call from my dealership today, they had flashed my truck tuesday for the rough idle and the reveing up. Then they had to pull the tranny out to replace the main. After it was all put back to gether. The diesel mech. took it for a test drive.
WELL know the durn thing has hardly any throttle response....GRRRRRRR......
They have had it for 8 days now and it will be tuesday bedore they work on it a again. Looks like ford timer is on the move towards the lemon law....
I will keep you post on what happens on the new flash disaster......
tryn to keep my diesel rolln,
PSDboy
Old Jan 23, 2004 | 05:01 PM
  #33
SBV45's Avatar
SBV45
Hardly any throttle response is not a result of the latest flash. I perceived a reduction in acceleration performance. It still goes pretty good. But it's not what I bought. Your complaint sounds like some other issues.
Old Jan 23, 2004 | 07:57 PM
  #34
softwizard's Avatar
softwizard
SBV45,
Exactly correct, my August 2003 built F-350 ran like a rocket and got great fuel mileage until the October flash. It still moves but definately not the same acceleration as new. Plus I lost 3 MPG on the highway and 2 MPG in town.
I've called Ford, I've talked to my Service Manager, now I await a flash that fixes them both. I hear it's in the works, but I'm not holding my breath.
Old Jan 23, 2004 | 08:18 PM
  #35
SBV45's Avatar
SBV45
It doesn't run bad now. If I test drove it today, I probably would still buy it. But, it's not what I purchased. I will wait for the next flash, if it is not right, I will want something in return. I'll cross that bridge when I come to it.
Old Jan 24, 2004 | 10:15 AM
  #36
"Luke" SdeS's Avatar
"Luke" SdeS
Fm PSDboy
Please, your input is important....and thanks for the time necessary to keep us informed...
Fm Kevin
now I await a flash that fixes them both....
Again, please keep us informed......
Old Jan 25, 2004 | 10:46 AM
  #37
This acceleration problem didn't exist till they flashed the truck, and changed the rear main seal. I don't think the rear main seal is the issue, but i could be wrong...
I will keep you up to date...
Thanks,
PSDboy
Old Jan 25, 2004 | 11:31 AM
  #38
Srry for another post regarding the flash, but any ideas what would have caused this issue with my truck????
I am pretty picky when it comes to my vehicle, maybe i shouldn't be like that. But we all payed prob around 35,000 to 50,000 for one these truck. inow that everything will not be perfect in the beginning, but it should be durn close. I heard andy say that every truck on the lot befroe they are sold get the newest and latest flash ( I BELIEVE).
Any info on what to do or what maybe to tell the dealer to check, would be great!!!
Thanks for all the help
Try to keep my diesel rolln,
PSDboy
Old Jan 25, 2004 | 02:01 PM
  #39
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
Powerstroke diesel boy,
I had the 12/12 flash for my 6.0L PSD/Excursion. This is the most recent flash that covers the 6.0L motor. It cured rough idle for cold weather operation and high altitudes, as well as tow/haul adjustments.
Secondly, there is a very defined process for "re-flashing" a vehicle and to ensure that it took properly!!! I noticed on my ticket that they flashed, then did another check or QA check of some sort. The techs time was billed out accordingly for all work, even the re-check after the "flash".
I have heard where there is a strict method to hooking up and doing the flash to ensure all records are properly uploaded and accepted by your truck's computer.
From what I have read and heard, having a tech and/or dealer that knows the proper procedure is vital!!!
All I know is that I had it done (12/12 update) and I am pleased... I am sorry that you and many others not.
Good luck,
Old Jan 25, 2004 | 03:50 PM
  #40
"Luke" SdeS
Fm Jeff Cook
there is a very defined process for "re-flashing" a vehicle and to ensure that it took properly!!!....
Very Good alert.....I just hope all on this sit see this important reminder....
Old Jan 25, 2004 | 04:28 PM
  #41
Thanks very much Jeff. I will find out what flash i got. My truck is being repair by ricart ford, and the largest on the east coast( suppose). I hope they have a good diesel tech, which so far it seem like it maybe.
I just want this durn thing to be right...
Thanks for the replys and if anyone else can and any help inof please do...
Thanks
PSDboy
Old Jan 25, 2004 | 09:02 PM
  #42
Beachbumcook
Got Diesel?
Here is website outlining the "flashes".
__________________________________
http://www.flatratetech.com/6literpo...l_updates.html
Good luck,
Old Jan 25, 2004 | 09:53 PM
  #43
al125's Avatar
al125
I just finnished a full tank after having the Jan flash (03E03). It was 16.1 mpg, 80% hiway/ 20% in town.This is down by .8 mpg from before the flash. Tim, I further checked on the T/H mode on my truck and it doesn't engage until I tap the brakes going down hill,but once engaged it stays
Old Jan 25, 2004 | 10:07 PM
  #44
al125's Avatar
al125
Old Jan 26, 2004 | 07:50 AM
  #45
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
That is exactly how it is supposed to work, how much weight were you pulling.
