Check engine light on --- EGR valve?
Old Jan 17, 2004 | 12:09 PM
KenBama's Avatar
KenBama
After having my 1998 F150 checked out. I was told that my check engine light is one due to insufficient flow from the EGR valve. Does this need to be replaced, and if so, can I do this myself without paying around 150.00 for someone else to do it?
Old Jan 18, 2004 | 02:11 AM
bob arrington's Avatar
bob arrington
yes you can, bob
Old Jan 18, 2004 | 09:29 AM
95 F150's Avatar
95 F150
It might just be carboned up. Do a search on yahoo for "EGR valve cleaning". There is a port in the upper intake that gets carboned up and needs cleaned out after some miles are put on the engine. On my truck I had to remove the EGR valve and the the throttle body to get access to the upper intake EGR port so I could break the carbon loose and vacuum it out. You don't want those carbon chunks getting in you engine.
Old Jan 18, 2004 | 12:07 PM
LxMan1's Avatar
LxMan1
Go to the 97-03 forum and search for EGR.
It is a common problem aon these ans a lot of times it isn't the EGR valve, it is the PTFE sensor.
Post the actual code that you got and you will be guided in the right direction.
Jimmy
Old Jan 18, 2004 | 01:59 PM
bob arrington
guess my answer was kind of lame,huh. ive probably been standing out in the cold to long again,good luck,bob
RollinK
38
Aug 11, 2021 04:13 PM
Freddie3026
Jul 3, 2016 05:17 PM
dcale101
1983 - 2012 Ranger & B-Series
30
Nov 19, 2004 06:05 PM
TexBow
Oct 14, 2003 08:05 AM
johnrebbb
Jul 30, 2003 04:50 AM
