Idling too fast and third and fourth barrel sticking open
This is a 1975 460 with I believe a Motocraft 4350. It has been sitting for two years and am trying to get it going. The engine starts fine but idles around 1700 rpm's. Also, when I open it up and kick in all barrels the the secondaries stay opened and then it idles around 4300 rpm's. They won't close until I shut the engine off and restart it. I have checked for vacuum leaks with propane and found none. I have actually directed the propane directly down the primaries and nothing happens. I have checked to make sure that the primaries are pretty much closed at idle and they are. If have turned the screw in and out on the front of the carb with no response. I only have the tranny, brakes, and vacuum advance hooked up and everything else plugged off.
Any idea what this could be? Is there an idle adjustment screw somewhere I am not seeing. I have tried adjusting the actual linkage and nothing happens.
Any help would be great!
Shane
Shane
