performance cam
Old Jan 17, 2004 | 09:41 AM
ford1967's Avatar
ford1967
performance cam
I have a 1967 f100 with a stock 352 in it and I was wondering what would be the best performance cam that I can buy that will sound good and give me some power. I was looking at comp cams and I found one that sounded good for the money but i am still a beginner at this stuff. the cam was at http://www.racenet.net/valve/cca-ford-352-428-cams.php
at the 275 deh cam. keep in mind that i dont have that much money. Please help
Old Jan 17, 2004 | 09:59 AM
f100guy's Avatar
f100guy
well don't get a cam without new lifters and don't get a cam that lopes too hard without a stall convertor or you will hate it.
Old Jan 17, 2004 | 10:16 AM
Ratsmoker's Avatar
Ratsmoker
I would look into some dual pattern cams. The FE heads are lacking on airflow on the exhaust. The Crane 343941 is a great cam for stock heads. You can go to www.cranecams.com to get the cam spec card for it.
Old Jan 17, 2004 | 10:51 AM
ford1967's Avatar
ford1967
what do you mean by dual pattern and how much horsepower would i be looking at
Old Jan 17, 2004 | 11:24 AM
fordman428's Avatar
fordman428
prolly around a gain of 30 hp maybe, www.jegs.com sells the crane 343941 cam and lifters for $179.99
Old Jan 17, 2004 | 11:43 AM
ford1967's Avatar
ford1967
cam specs
216/216 at .050"
272/272 advertised duration
533/533 lift
110 lobe separation
Good idle, daily usage, off road, highway towing, fuel efficiency plus performance, 2600-3000 cruise RPM, 8.75:1+ compression ratio, 2000-5000 RPM power range
crane energizer cam
what do you think of it and would i be able to idle w/out putting in a stall converter or an new intake.
thanks
Old Jan 17, 2004 | 01:18 PM
Ratsmoker's Avatar
Ratsmoker
Dual pattern cams have either more or less duration and lift on the exhaust lobe. It is usually more. For the FE you want more if you are running stock heads. The 343901 is a great dual pattern cam for people who want an upgrade in performance but don't want to deal with loosing low end torque, vacuum etc.... With the Edelbrock heads you should be running a single pattern or something close to a single pattern.
Old Jan 17, 2004 | 03:49 PM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Hey Rat....I like that 343941 Crane cam...I wonder how well that will work with my 406 head on my 390?? HMMM
Old Jan 17, 2004 | 04:29 PM
ford1967's Avatar
ford1967
thanks
Old Jan 17, 2004 | 04:35 PM
ford1967's Avatar
ford1967
with that cam at jegs how much more extra hp would i be pushing and would it rumble more than stock. Thank you all
Old Jan 17, 2004 | 04:42 PM
Ratsmoker's Avatar
Ratsmoker
You will have a slight lope with the 941. Nothing nasty. You should pick up at least 35HP over the stock truck cam and maybe more. It would work great with the 406 heads.
Which cam at jegs?
RapidRuss's Avatar
RapidRuss
Ford1967....They claim a GOOD Idle.... Not smooth.... As far as how much HP.. I couldnt tell you? I guess it would depend on the combo..etc...you have it set up with? Good Luck!! Russ..
Old Jan 18, 2004 | 02:21 PM
Alz Ryde's Avatar
Alz Ryde
Thumbs up
Considering he said he's on a budget, I would check out Northern Auto Parts, since he can get the same cam with lifters for $99.00 as opposed to $179.00 for the same thing. Nothing aginst Jegs, as I've bought from them before. But come on, $79.00 extra just to get a sticker to put in your window, and another catalog? Al
Old Jan 18, 2004 | 05:32 PM
gtex's Avatar
gtex
Sounds like a "cam only" price.
Jeg's and Summit almost always have the best prices...just my experience. If not, I need to check out these Northern Auto guys :-)
Old Jan 18, 2004 | 06:57 PM
Alz Ryde's Avatar
Alz Ryde
Hi Gtex, I talked to them last week, as I was pricing a cam, and was quoted " cam and lifters, its our everyday price ". Just trying to pass on some cost savings for some of these guys, as these things get expensive to work on sometimes. Al
