Sponsored by: Innova
Radio sucks
Old Jan 15, 2004 | 07:37 PM
wickymustang's Avatar
wickymustang
Radio sucks
I have a 1995 F150, with an Awia cd player and stock speakers, it was installed prior to me purchsing it, and everytime I hit a bump a speaker stops working til I hit another bump, how do I fix this?
Old Jan 15, 2004 | 07:58 PM
CrazyFordMan's Avatar
CrazyFordMan
prolly a short in the dash behind the deck or at the speaker itself
Old Jan 15, 2004 | 07:59 PM
triton_2002's Avatar
triton_2002
The easiest solution would be to avoid all the bumps
Just kidding, there is probably a loose connection somewhere. Do all the speakers give out at the same time? If so I would check the conections at the back of the radio. If only a certain speaker is giving out, I would check the connection at that speaker. If you do find the loose connection, replace it with a tight fitting terminal or better yet solder it. Hope you find your problem!
Old Jan 16, 2004 | 06:22 PM
acerockola77's Avatar
acerockola77
Pinpoint which speaker it is, look up the color code here then see if there is a loose connection first in the speaker, then you might pull your radio and check the connection there.
Old Jan 18, 2004 | 04:46 PM
wickymustang
It's not just one speaker, they all do it, but only one at a time, it goes around the cab repeatedly.
Old Jan 19, 2004 | 09:33 PM
wickymustang
All the speakers are connected correctly and firmly, I will have to jerk the head and check it in the dash, if that's not it I will be back to look for more ideas.
rr-merlin
Nov 15, 2024 01:24 PM
FlaresideF150
May 30, 2011 08:53 PM
pinesman
Nov 9, 2006 06:23 PM
Luckyfishbone
Jan 7, 2004 10:38 AM
