Engine sputters under load
Old Jan 15, 2004 | 10:48 AM
88bronk's Avatar
88bronk
I bought a 84 LTD that sat in a field for a few years. I replaced the fuel pump, inline filter, and cleaned out the tank but not real good. The engine idles smooth. Accelerating slowly it runs good. With hard acceleration it sputters. And higher than 30 mph it sputters. When I let off the gas it quits sputtering. After a few minutes the engine light comes on. Does anybody have any ideas.
Old Jan 15, 2004 | 11:50 AM
EPNCSU2006's Avatar
EPNCSU2006
Pull the codes from the computer and see what you come up with. That will give you a place to start looking...
Old Jan 15, 2004 | 04:20 PM
lancer's Avatar
lancer
If it's an 84 is it feuly? If it is carbed get it cleaned. The floatbowls are likely slugged up. How did you clean the tank. The only good way is to remove it have it flushed. Also check the ingnition modual. It may need to be replaced.
Old Jan 15, 2004 | 09:30 PM
EPNCSU2006's Avatar
EPNCSU2006
Woops, I should read more carefully. I saw '88 in the user name I guess. It may be EEC-III for spark control, but I'm not sure if that outputs codes or not. Does the accelerator pump work? I'm not terribly familiar with carburetors, but it does sound like it's a fuel problem.
Old Jan 15, 2004 | 10:07 PM
fordeverpower's Avatar
fordeverpower
i thought they had cfi junk or something of that sort. Could it be a bad injector in the cfi or tbi?
Old Jan 16, 2004 | 12:55 AM
88bronk's Avatar
88bronk
Sorry guys. I should have added that it is a 84 Cown Vic witha CFI system. My Haynes code book says the 2 digit codes only go back to 1988. It's been a couple of months and I don't remember the one code, but I don't think it had anything to do with the engine. I'll check again. Thanks for the response.
Old Jan 16, 2004 | 09:41 AM
88bronk's Avatar
88bronk
I'm not sure which EEC system I have. I thought it was a Duraspark II. How do you tell? And which EECs will give codes. Anyone familiar with CFI systems?
Old Jan 20, 2004 | 09:38 AM
88bronk's Avatar
88bronk
I can't figgure if it is the fuel or the electronics. I'm open to all suggestions.
Old Jan 20, 2004 | 07:16 PM
lancer's Avatar
lancer
Dura spark II only controls your spark. It has nothing to do with your fuel. Tell us if it has a regular carburator or injectors. I'm sure you'll find it is just a carb in 1984. I am also sure you'll find it needs to be cleaned in a big time way. If you can't do it yourself find someone who can tear it down and rebuild it for you. Good luck.
P.S. Try a new coil. There cheap and easy to replace.
03XL
1997 - 2003 F150
Mar 4, 2014 11:17 PM
Drgslayr
1983 - 2012 Ranger & B-Series
Jul 16, 2009 02:49 PM
hamsteria
Nov 11, 2006 12:13 PM
88bronk
Jan 21, 2004 04:44 PM
88bronk
1978 - 1996 Big Bronco
Jan 21, 2004 01:21 PM
