1978 - 1996 Big Bronco
302 engine sputters under load
Old Jan 18, 2004 | 12:13 PM
88bronk's Avatar
88bronk
I bought a 84 LTD that sat in a field for a few years. I replaced the fuel pump, inline filter, and cleaned out the tank but not real good. The engine idles smooth. Accelerating slowly it runs good. With hard acceleration it sputters. And higher than 30 mph it sputters. When I let off the gas it quits sputtering. After driving a few minutes the engine light comes on. This car is a Crown Vic with a CFI fuel system. Does anybody have any ideas.
Old Jan 18, 2004 | 05:32 PM
RA81222's Avatar
RA81222
check plug wires and dist cap and rotor. I have a 302 in my bronco and under load @ going up hills it would miss badly. Plug wires were arcing to objects they made contact with. You can check them at night time(no lights on in garage, the darker the better) with engine running. pop hood and rev. engine to about 2000rpm and hold steady and watch closely for arcing. you will also see plugs actually glowing. good luck.
Old Jan 18, 2004 | 05:55 PM
BillyBob69's Avatar
BillyBob69
What twisted limb said.
Old Jan 20, 2004 | 12:47 AM
88bronk's Avatar
88bronk
Thanks I forgot about that.. I've done that before but only at idle. Maybe thats why I never saw the plugs glow? I'll try it.
Old Jan 20, 2004 | 08:24 AM
BillyBob69's Avatar
BillyBob69
You might also check for a clogged cat. not all of em rattle when they go bad.
Old Jan 20, 2004 | 06:25 PM
Norm Carter's Avatar
Norm Carter
Look at the cheap and easy stuff first: Rotor, cap, plug wires, plugs. Then on to fuel filters, cat if there's still a problem. Only time my 86 302 sputtered on long uphill grades, I found a cracked insulator on one plug.
Old Jan 21, 2004 | 10:59 AM
88bronk's Avatar
88bronk
How's the best way to check for a plugged catalytic conv?
Old Jan 21, 2004 | 01:21 PM
Norm Carter
I posted the procedure on this board a couple of days ago, can't recall the name of the thread though.
Bondsman Chris
May 15, 2024 03:00 PM
Memphis_Sean
Nov 15, 2015 12:42 PM
shanksyamaha
2004 - 2008 F150
26
Apr 2, 2013 06:59 PM
Drgslayr
1983 - 2012 Ranger & B-Series
Jul 16, 2009 02:49 PM
seaview
1997 - 2003 F150
Aug 15, 2003 03:23 PM
