390 Stock HP?
Old Jan 15, 2004 | 06:39 AM
somethingurnot's Avatar
somethingurnot
390 Stock HP?
I picker up at ford with i think a 68 or 72 390. What HP does the 390 have?
Old Jan 15, 2004 | 10:32 AM
fordman428's Avatar
fordman428
if its 4 barrell its around 300, 2 barrell a little less
Old Jan 15, 2004 | 11:43 AM
buzzard's Avatar
buzzard
255 @ 4400 rpm in '68
Old Jan 15, 2004 | 12:05 PM
SFC DAVIS's Avatar
SFC DAVIS
Same for 69- 255HP- 2bbl
Comp Ratio- 8.6:1
Old Jan 15, 2004 | 04:54 PM
jamlove's Avatar
jamlove
hp ratings change
One thing to keep in mind, just FYI: in 1972 the standard published horsepower ratings system changed. Before 72, you'll see hp ratings given as unloaded, or GROSS. Then in 72 the hp ratings became NET, after all accessories loaded on. The figures seem to sharply decline, but in fact a 1971 390 and a '72 390 are exactly the same. Just the ratings changed.
Here's an article on it:
http://www.iwaynet.net/~gl&lisk/1972ta.html
There were also some emissions laws that dropped output hp in '72, according to stuff I've read on the net.
So you most likely have 255 @ 4400 rpm GROSS, and about 180 NET. Give or take.
Old Jan 15, 2004 | 05:10 PM
fordman428's Avatar
fordman428
it was in 73 when the emission laws started you can easily tell the difference i had a 72 390 with barely any emissions and a 73 that was loaded up with emissions, the hp dropped quite a bit.
1975 f150 360
16
Jan 18, 2009 11:04 PM
gunnabebad
18
Jan 16, 2004 03:22 PM
2ndmouse
Dec 18, 2003 11:57 PM
zsir
Feb 14, 2003 10:22 AM
fearthis390
20
Dec 1, 2002 09:59 PM
