Gas guage does not work????
Old Jan 14, 2004 | 05:38 PM
muddyford75's Avatar
muddyford75
Lightbulb Gas guage does not work????
i have a 1975 ford f250 with a 390 motor and find myself filling up with gas all the time so i dont run out. I do this because my guage reads empty all the time even when shes full. i have a wire hooked to the top of the float and a ground off of that. The main wire runs up and over the door and i see where it comes out down by my E break handle but from there i dont know where to hook the wire up. Thanks for the help.
Old Jan 14, 2004 | 10:24 PM
Mil1ion's Avatar
Mil1ion
You can't just hook-up a wire to it.
The sending unit's operate off a 5.0 volt pulse from the instrument cluster voltage regulator.
Either you remove the sending unit and clean it up until it works again or you replace it.
Click this
http://www.clubfte.com/users/mil1ion...strations.html
and see the second row of illustrations
Old Jan 15, 2004 | 08:30 AM
73Custom's Avatar
73Custom
Does the guage move at all whent he key is turned on? With the key on, momentarily ground the sender wire - does the guage move? Test sender wire with test light - do you get a dim pulsing light? Do your other guages work?
Check these and tell us what you find.
Marty
Old Jan 15, 2004 | 05:33 PM
muddyford75
the guages do not move when you turn the key or start the truck but the rest of the guages do work fine.
Old Jan 15, 2004 | 05:42 PM
Mil1ion's Avatar
Mil1ion
Take the connection off the sending unit and attach it to ground ( for a short time only).
The needle on the gauge should Pin itself to the right hand side of the gauge.
This means you have a good circuit just that the sending unit won't read it.
Again, unless the float is full of gasoline you need to clean the S/U up or replace it.
You can also put a test light on the wire to the fuel sending unit and see if it flashes with a steady pulse.
Old Jan 16, 2004 | 11:24 AM
RBettis's Avatar
RBettis
Talking
on my 79 there is two wires for the sending unit. one at the rear of the frame and one about half way down. when i got my truck the gauge didn't work either. ran new wire from front one and gauge works fine.
Old Jan 17, 2004 | 01:57 PM
muddyford75
where do you connect the sending wire up under the dash/gas guage.
Old Jan 18, 2004 | 11:07 PM
gene2no's Avatar
gene2no
My 75 came with dual tanks, switch for tanks near heater control. If you have this, check the inline fuse that is located about where the back of the radio. I think you can see it from under the dash. My wiring diagram shows the sending unit goes directly to the gauge to the voltage regulator mentioned by Mil1ion.
cedub
Oct 26, 2011 02:33 PM
KH85
Aug 11, 2011 01:34 PM
Bagged70F100
21
Mar 9, 2004 05:47 PM
DrkPhanstm
Mar 4, 2002 08:46 PM
