Backlash adjustment
Old Jan 14, 2004 | 10:43 AM
Errgo's Avatar
Errgo
Backlash adjustment
I have a 93 Bronco with an 8.8 differential and I need to know if the ring gear backlash is adjustable?
Old Jan 14, 2004 | 11:35 AM
RTM's Avatar
RTM
Yep, but you have to take it apart to do so and when there is play there must be some worn parts. It just doesn't loose it's adjustment for no reason. If you choose to reset the BL then you need to confirm a good wear pattern as well to insure things will run correctly. You may also develope a whine from the rear if you do this. That will be form the worn gears getting moved from there worn position.
aidandj
Nov 25, 2015 02:40 PM
xtal_01
Nov 8, 2015 03:53 PM
nicksorenson
Jul 8, 2014 01:57 PM
woodtrucker
Dec 23, 2013 08:37 PM
02FX4Dude
Aug 20, 2004 05:18 PM
