Glove box
Old 01-12-2004, 08:52 PM
elliott's Avatar
elliott
elliott is offline
Glove box
Can anyone tell me how to get a new glove box (cardboard?) into place without tearing it up? Thanks, Bob
Old 01-12-2004, 08:57 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
Remove the heater box first.
If that doesn't work,
You will have to bend it ever so lightly to Push & scrape it into position,
Old 01-13-2004, 01:40 AM
GeneStoner's Avatar
GeneStoner
GeneStoner is offline
I covered the exterior of mine with metal tape (for use in HVAC applications) prior to re-install. It didn't make it any easier to install per se, but it should keep the somewhat flimsy unit from deteriorating prematurely...
Old 01-13-2004, 12:47 PM
bigredtruck's Avatar
bigredtruck
bigredtruck is offline
I fiberglassed the outside of mine, undercoated the inside, then had to wait a few months to drop the heater to get it in.
So, unless you can squeeze it through the opening with luck and not tear it, it looks like from under the dash is the easiest way.
Old 01-13-2004, 01:48 PM
biz4two's Avatar
biz4two
biz4two is offline
I was pretty successful installing from the front. I did remove the glove box door and it was about 95 degrees out. That I am sure helped some.
Old 01-26-2004, 11:25 AM
jbird's Avatar
jbird
jbird is offline
Smile replacement glove box
go to this address for a plastic glove box that you can install through the opening very simplyhttp://broncograveyard.com/products/...love%20box&sy=
Old 01-28-2004, 07:07 AM
classyfish's Avatar
classyfish
classyfish is offline
Take the door off, but also the latching mechanism on the top inside of the opening . Its held by 2 screws and pushes off with a little force. Then you can (massage) the box in easily, just dont force it. Cardboard is flexible, just me careful.
Old 01-28-2004, 12:39 PM
beartracks's Avatar
beartracks
beartracks is offline
Turn it sideways and push one end in first. I used the plastic one and it's good.
Old 02-05-2004, 01:06 PM
cigarxtc's Avatar
cigarxtc
cigarxtc is offline
Check out the FTE Tech Articles. There's a new article on there, that might provide you with what you're looking for. When I get the free time, I make them and put them up on Ebay. If ya need help or have questions about the process then lemme know. If any of you local people need help lemme know. I've got all the metal working tools in my garage to make these.
Old 02-05-2004, 02:20 PM
pro3qtr's Avatar
pro3qtr
pro3qtr is offline
I got a new one from the dealer.
Have not installed it yet.
