hmmm... I will have to check into that. I have been so busy looking at the fuel pump and the fuel system, I never even thought to check the computers relay. I did manage to check the fusable links but I didnt even consider the relay for the computer. Can I bypass the relay like on the fuel pump relay to see if that might be the problem?
I doubt it. Of course, if it were me, I'd be following a wiring diagram and poking around with a voltmeter to see where the fuel pump circuit is losing power, but that's just me.
alright, as soon as it stops raining out (and now that I have a manual), I will see what I can or can't find on the electrical side of this beast. I call her a beast because you and I and the rest of the world knows that it is going to be somthing very simple but I won't be able to locate it until I spend a couple hundred bucks. Murphey's Law, i think I live by it.. lol..
But seriously, thank you for your help and patience with me as I try to figure this out. Thanks everyone!!
hey i got a 87 also and it did the same thing to me but anyway check the small black wire on the negative battery post . it is a direct ground to the computor.if it fell off or broke or coroded off it shuts down the putor and wala your walkin just like me it took 2 wks to find a broken wire for me also ckeck all grounds good luck
