4.0 SOHC Cam sensor question
Old Jan 12, 2004 | 01:57 PM
Dave257's Avatar
Dave257
I have a 2002 ranger with the sohc motor that will not idle right. it runs fine, and idles ok when cold. but when warm it idles at 600 rpm and will buck every few seconds. I replaced the IAC with no help. When I hold my hand over the exhaust pipe i can feel it blow when it bucks as if its firing when an exhaust valve is open. My question is can an CKP sensor fail like this and cause a problem only at idle? Thanks for any help.
Dave256
Old Jan 12, 2004 | 10:48 PM
Blly177's Avatar
Blly177
try cleaning your iac and maf first. also try this stuff called sea foam and reset your computer there is a very remote possibility that it is the camshaft position sensor
but sounds to me like you need new plugs
Old Jan 14, 2004 | 01:03 PM
Dave257's Avatar
Dave257
Thanks for the info. I don't know what sea foam is. can you explain?. I have a set of plugs and wires i am going to try this weekend. will let you know.
Dave
Old Jan 14, 2004 | 08:31 PM
Blly177's Avatar
Blly177
seafoam is this stuff that you suck into your engine via a vaccum line and it cleans the carbonout it smoothed out a lot of peoples idles out.
http://www.seafoamsales.com/motorTuneUpTechGas.htm
also if you have an explorer check out ford-trucks.com
Old Jan 14, 2004 | 11:55 PM
hreed's Avatar
hreed
Best bet is to put a vacuum guage on it and see what is happening. That will tell you a lot of info in a short time. The SeaFoam is great stuff if you need it but I'm not sure you do. Is the check engine light on? That is the first line of defense. Also check your brake lights. Some of these things will idle poorly if a brake light is burned out.
Old Jan 15, 2004 | 12:45 PM
Dave257's Avatar
Dave257
More info
Ok, put a vacume gauge on it and it is steady at about 19 inches. when it bucks it drops a couple of inches and recovers. No Cel, but i pulled the codes and it had a p0300 (multi clynder misfire) and when i reset it it comes back when it bucks. I checked the timing and it looks to be bouncing around at idle. between 16 deg and as much as 27 deg. that might explain the bad idle. misfiring at low rpm and when at higher rpm the timing is advanced and steady. any ideas.
thanks
Dave.
PS: Anyway to disable the advance to see it cures the idle problem?
Old Jan 17, 2004 | 07:27 PM
Dave257's Avatar
Dave257
Got it fixed !
Well I changed plugs and wires and it didn't help. So I took it to the ford dealer and talked to the service rep. He had it checked and said they would change the ECM, but would not offer me any promises that that would fix it. I had them change it and figured if that dosen't do it I can change the rest of the senors. Low and behold the new ECM fixed it. live and learn i guess.
Dave
Old Jan 22, 2004 | 09:46 PM
hreed's Avatar
hreed
Glad to hear it's fixed. Just a shame you had to go to the dealer to get it done. ECM was going to be my next suggestion! (lol) Don't forget about the SeaFoam tho. It really is great stuff for the engine and transmission. I kept my plow truck tranny alive for about a year using that stuff. It got to be a routine between me and the truck. I would drink a cup of coffee; the truck would drink a pint of SeaFoam.
FirstCarWasAFord
Jul 3, 2016 06:12 PM
BogginDave
Mar 30, 2016 04:09 PM
Ryleystr
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Feb 12, 2016 01:24 PM
Ranger2003
1983 - 2012 Ranger & B-Series
May 19, 2012 08:25 PM
photog3740
Jan 6, 2005 01:18 PM
