you can check the site and pull that tire up too. Probably pretty much the same size though, i would imagine.
And yes, no more 1/4 mileing for Tom.
I can always toss on the Kumho's in 10 minutes and be ready to go though. That's why I've decided to keep them, so when I get the urge for Moroso, I can toss em on and go go go!!!!!
Originally posted by BrianA you might run out of motor by the end of the 1/4 mile with the 4.10 rear end, especially if you are running short tires. But, apparently Tom has that set up and it works for him.
Only unless you have your chip tuned for the gear change and the spead limiter removed, then you wont have any problem. Without the speedo correction though, your speedo will show you going faster than you really are, therefore cutting you off at an indicated 98mph when your really only going 85.
