2000 exp po1401 engine code
Old Feb 12, 2009 | 08:10 PM
hoyt0119's Avatar
hoyt0119
Question 2000 exp po1401 engine code
Hi I have a 2000 exp with the 4.6 engine. I have replaced the pdfe and the pcm relay. I have also cleaned the egr valve and cleaned out the carbon out of the throttle body. I dont know what else to do. Could it be the ecm? I have noticed that the transmission in not going into gear like it is suppost to. It may just be due for a new filter but I have heard sometimes these symptoms are related. I am sure that you guys have talked about this a thousand times so if there is a thead that I could look at it would really help. Thanks for looking Jamie
Old Feb 13, 2009 | 07:04 AM
projectSHO89's Avatar
projectSHO89
Where did you purchase the DPFE sensor?
If it wasn't a Motorcraft of the new plastic style, take it back and get the OEM replacement unit.
Old Feb 13, 2009 | 04:33 PM
hoyt0119's Avatar
hoyt0119
I bought the dpfe from ford dealer. I pulled the vaccum line off of the egr valve today. At idle I am getting a pulsating low vaccum coming from the DPFE sensor. I unplugged the sensor and got no change. Then I tried to unplugg the ecm sensor and got no change again. I think that I got a defective DpFE sensor. I think the diaphram in it may be bad.
mprsox
Jul 28, 2019 01:12 PM
MorrisClan
Aug 9, 2016 09:15 AM
phillyfreak
Aug 12, 2011 11:19 PM
Kalve
WTB - Ford Trucks & other vehicles
Apr 14, 2011 06:55 AM
IlliniJoe
17
Feb 17, 2008 06:07 PM
