D2VE A2A heads
Old Jan 11, 2004 | 09:05 AM
RichardMaerz69's Avatar
RichardMaerz69
D2VE A2A heads
sorry to bother anybody,but still wondering about these heads
good,bad,or just plain junk.?
Old Jan 11, 2004 | 12:35 PM
greenhighboy's Avatar
greenhighboy
They are junk. They have an open chamber that causes the engine to ping bad because there is no quench area. If you want a low compression motor get a set of D3's. If you want to raise the compression get a set of C8's,C9's,or D0ve's.
Dennis
1999 F-350 Powerstroke
1977 Highboy 429 4-speed 35"s
1972 Ranger on a 1978 F-250 4x4
frame 466 Pulling Truck
Old Jan 11, 2004 | 01:23 PM
proeliator's Avatar
proeliator
Yup, junk. The D1ves are a fine early head too.
Old Jan 11, 2004 | 04:06 PM
cobrajet's Avatar
cobrajet
hi Richard, talk to someone who knows don't listen to the others. the 1972's are a very unique head it is the only year ford made an open chamber design,starting the lower compression years. i have run these heads for many years on a block that has been bored .060 over running dished pistons with a compression ratio around 9.6:1 and have had no problems!! people assume that these heads are junk because they are open chamber but that is just not the case. my H.P. was around a very conservative 425 ponies. you still need to port the exhaust, getting rid of the bump helps out in any of the big block designs. going with the d-3's will lower your compression lower than if you were to use 1972's.. these heads have lasted well over 110,000 on a nicely built engine that had seem every day driving at and above 4,000 r.p.m.'s since it was first started. if your not going to run the sheet out of them why build an engine!!!!!!
so if i were you hold on to them there are not many of those heads around. C.J.
Old Jan 11, 2004 | 04:14 PM
RichardMaerz69
thank you very much for the info very helpful. I will run the hell out of them in a 1975 1/2 ton. Just looking for tranny & mounts.
Old Jan 11, 2004 | 04:31 PM
proeliator's Avatar
proeliator
Uhhh, maybe you should refer to the sticky at the top of this forum. I didn't say they were "junk" merely because of their open chambers, I simply said they were junk. I'm trying to help the guy out so he doesn't sink any money into worthless heads. I'm so glad they worked for you cj but truth goes beyond your own personal experience. But let me expound. They are junk because they are prone to cracking and detonation. There is a reason that Ford changed their design after only one year in production. Talk to ANY Ford head specialist and they will tell you they are no better than paper weights. If you don't believe me, ask Scott at www.reincarnation.com. He's the best Ford 385 head man this side of the rockies. He'll tell you to chuck 'em too. Not trying to bear a bearer of bad news, just trying to help you out.
Old Jan 11, 2004 | 06:20 PM
greenhighboy
cobrajet
I do know what I'm talking about. I have a set of D2's on a 429 with flattops now and it rattles its *ss off. I made the mistake of putting these on in place of C9's to lower the compression and it rattles just as bad now as it did before. I have a set of D3's going on soon. If you are using dished pistions and D2 heads you probably have a comp. ratio of 8.6:1. You need flattops to get 9.6:1 with 92cc heads. D3's have the same cc combustion chamber as the D2's so he won't lower the comp. ratio by switching. I agree with everything proeliator said and I did leave out the D1 heads on my first reply.
Dennis
Old Jan 11, 2004 | 06:50 PM
RichardMaerz69
thanx for the input ,you guys obviously know more about the heads than i do .I'd better trackdown another set of heads just incase one of you is wrong .I'm hoping to punish it this summer
Old Jan 11, 2004 | 08:14 PM
There Goes The Neighborhood's Avatar
If I remember correctly, D2VE heads have closer to 98 or 99 cc chambers, and a "bathtub" shape, resulting in low compression and almost as bad of a detonation problem as Open chamber heads on a stock 400. The D3VE is a much improved design, will actually raise compression a hair, and improve detonation resistance. IMO, you should stay away from the D2's and either get D3's or D0's(or equivelant).
Old Jan 11, 2004 | 09:43 PM
cobrajet's Avatar
cobrajet
well everyone has there right to their own opinion, that's cool, i have never had a problem with this set-up and like i said in my post they have 110,000 THOUSAND + miles and have never had a problem. everyday beating the crap out of it..
and my compression is 9.6:1 i know this... i can see why the other guy had spark knock you can't run flat tops with these heads ( D-2 )
all i can tell ya is use your own judement, if i can use this set-up with no problems it looks like someone may not have the right knowledge to make theirs run the same..
this is all i'm going to say i'm not going to get drawn out into a shouting match about what i know and what other say also.
take it easy Richard, hold on to those heads. C.J.
Old Jan 11, 2004 | 10:15 PM
proeliator's Avatar
proeliator
That must be it. Ford engineers didn't have the knowledge to make this head design worth a damn so they junked it after a single years production. If only they had your wisdom
Listen Richard, Cj was right in that there isn't any point in getting in a pissing contest over this, and we are both trying to help you. My final advice is to re-suggest that you talk to some 385 head specialists and see what they say before you make a mistake you'll regret. As much as I hate to see this bad info getting out...I (we) made our counterpoint so I'll leave it well enough alone. 'Nuff said.
Old Jan 12, 2004 | 11:55 PM
DeanG's Avatar
DeanG
Cobrajet
Just curious, you said you were certain you are running 9.6:1 compression with dished pistons and D2VE heads. How do you know that it is 9:6 to 1?? Have you cc'd your heads and the dish in the piston? Do you know what your deck clearance and head gasket thickness is? Help me out here, I'm trying to do the math with my compression ratio calculator and known Ford data for these heads and dished pistons and it's not workin for me.
Old Jan 14, 2004 | 02:59 PM
scroob's Avatar
scroob
There is always going to be somebody who says it works for them, no matter what the common consensus is.
The above poster is the only person I have ever run into that defends the D2 heads. Everybody else (including some very savvy people on the Network 54 board) say dump them.
My theory is that "half a million people can't be wrong."
It's great that the D2 heads work OK for him, but how does he know the D0VEs or D3s won't work a lot better?
Old Nov 12, 2020 | 04:06 PM
Jason Gallegos's Avatar
Jason Gallegos
Any of yall know where I can actually buy cast iron heads for my 429? I've been looking for a few months and its hard to find old heads around here
Old Nov 13, 2020 | 10:41 AM
mark a.'s Avatar
mark a.
What heads are you looking for and why old iron heads ? By the time you find a old set they will probably need everything and still not really fit the bill depending on what your goal is. If you have nothing and need everything then a new set of aluminum heads would be the way to go.
