Sponsored by: Auxito
Spark plugs
Old Jan 10, 2004 | 10:43 AM
Fat Ford Boy's Avatar
Fat Ford Boy
Spark plugs
As I've stated before, I am NOT a mechanic, so I rely on other folks input, their knowledge, and their experiences.
SO, with that in mind, here it goes.
We own 2 F-150 Super-Crew 4 X 4's.
A 2001, and a 2002. Both with 5.4's
Neither one is in a bind/needing a set of spark-plugs.
BUT, what I am wanting to know, is this. Is there a better plug when I do replace them, than the originals ??
Thanx,
Old Jan 10, 2004 | 12:52 PM
superrangerman2002's Avatar
superrangerman2002
I'm going to stick my head out and say that there are not any better ones than the OEM Motorcraft plugs.
However I am currently using Autolite Double Platniums in my F150 and my wifes Taurus.
And I would also reccomend the Autolites DP in addition to the Motorcraft DPs.
As far as I know they are the only DPs on the market.
Old Jan 10, 2004 | 01:21 PM
Fat Ford Boy
Thumbs up
hanx, for the response !!
Old Jan 10, 2004 | 05:46 PM
Rotorman's Avatar
Rotorman
My experiance
Hey Ford Boy.
My pickup has the 4.6 V8, and at 97,000 (+/- a few) I decided to change the plugs. The plugs that came out were installed at the factory. I was shocked!! The electrode was worn down to the porcellian, the darn gap must have been a 1/4" and the truck was running just fine!! Well I broke down and replaced them, with the same plug (p/n) number and they are still in there at 143,000 (+/- a few), and the truck still runs fine. Only fly in the ointment...shoot changing those rascals was an absolute pain...darn near have to take the tail lights out and work forward taking stuff off just to reach the rear ones... total pain in the butt. Hope this info is of some help, Rotorman
PS.. If anyone out there know the "trick" to changing the rear ones, please let me know... got a programmer, and new intake system coming, and really should change those DARNED plugs again!!
Old Jan 10, 2004 | 08:59 PM
BlueOvalFitter's Avatar
BlueOvalFitter
Rotorman,i'm almost in tears from laughing so hard at that comment about "taking out the tail lights"....
Ford Boy,he is correct; go back with Motorcraft OEM.
Old Jan 10, 2004 | 09:06 PM
Racerguy's Avatar
Racerguy
Rotorman take a look at https://www.ford-trucks.com/forums/s...2B%25252Bplugs
Yours is a bit different with plug wires instead of COPs but the idea is the same.
Just be patient when you're replacing the plugs
Your taking out the taillights comment reminds me of the old joke about the gynecologist that was training to become a mechanic. He got extra marks for rebuilding an engine through the tailpipe.
Old Jan 13, 2004 | 10:26 AM
Fat Ford Boy
Thanx, all !!!!!!
Old Jan 13, 2004 | 08:00 PM
seldont's Avatar
seldont
I concur with the Motorcraft or the Autolite double platinums. When doing the passenger side unbolt the wiring box thingy from the firewall and pull it out of the way and on the driver's side you will remove the power steering resevoir. No big deal on either one. I have a 5.4 and it took me 4 hrs the first time. Can do it now in two hrs. It is a pain but take your time and you will do fine. Do not be surprised if the new plugs have more threads than the old ones. Mine do. Just as long as the reach from where the plugs seat to the tip of the plug is the same.
