Rear Spring Question
Old Jan 8, 2004 | 04:45 PM
Jag Red 54's Avatar
Jag Red 54
Question Rear Spring Question
I've been experimenting with the number of springs on the rear of my 54 f100. Six was good, but maybe just a little too low. So I decided to try seven. It seems a little too stiff even with the new plastic liner material installed. So, I'm going to take out one and go back to six. My question involves the replacing of the bushings where the main spring connects to the shackles. The one on the driver side seems to have a little movement to it from side to side when the axle is removed. The pass side is much more secure. I interpret this as wear in the bushing. How are these bushings removed? Are there any slick shortcuts, or is it just APITA? Special tools? Any light that you can shed on this topic will be appreciated. Thanks, John
Old Jan 8, 2004 | 09:34 PM
fordgo's Avatar
fordgo
john
are you talking about in the spring itself? if thats the case i used a piece of all thread bar and on one end i placed a large socket piece of pipe whatever ya got that clears the bushing but hits on the the spring eye and on the other end a washer and nut that hits the bushing but not the spring eye then crank away on the nut and it will pull it right out
Old Jan 9, 2004 | 09:21 AM
Jag Red 54's Avatar
Jag Red 54
Sounds like a plan. Thanks, John
Old Jan 9, 2004 | 11:33 AM
51dueller's Avatar
51dueller
Here's an easier way to remove them. Find a long socket that is slightly smaller than the spring eye and hit the end that attaches to the ratchet. They will come out like nothing.
Old Jan 9, 2004 | 01:05 PM
Jag Red 54's Avatar
Jag Red 54
Well, that sounds easy enough. Howabout installing the new ones? Can you just tap them into place? John
Old Jan 9, 2004 | 01:26 PM
51dueller's Avatar
51dueller
You should be able to with a rubber hammer.
Old Jan 9, 2004 | 01:28 PM
War Wagon's Avatar
War Wagon
Ya you should be able to ,just use a little anti sieze or grease.
Old Jan 9, 2004 | 01:42 PM
War Wagon's Avatar
War Wagon
If allelse failes use a hacksaw blade and cut a slot in the old bushing and take a small punch and fold the corners over and it should almost fall out.Sometimes its a pain to cut through the rubber .
F350JOHN
Oct 19, 2023 09:12 AM
prorad
Jul 15, 2013 07:02 AM
Derrick lane
Dec 14, 2010 02:06 AM
cadunkle
Nov 16, 2010 08:35 PM
Jag Red 54
Jan 24, 2005 03:03 PM
