need front hub assembly
Old Jan 7, 2004 | 06:40 PM
norcalcapri's Avatar
norcalcapri
are there any other places besides the dealer that i could obtain a front hub assembly, they told me its a dealer only part but theres gotta be some other place i can acquire a good one without all that money going down the drain. ive got a 96 explorer xlt 4dr 4wd if that helps. thank you
-paul
Old Jan 7, 2004 | 06:58 PM
Opera House Works's Avatar
Opera House Works
That should be easy. I bought a Timken w/sensor, same as factory, for $140 from local parts store. NAPA wanted $280. Average price I've heard is about $170. Shop around.
Old Jan 7, 2004 | 07:00 PM
norcalcapri
this worked perfectly fine for you? also do you know if a messed up hub assembly would cause my abs light to come on?
thanks,
paul
Old Jan 8, 2004 | 04:27 AM
Opera House Works
The bearing does have the ABS wheel sensor mounted on it. This you can purchase seperately. Because of the design, these bearings contain very little grease. That allows the bearings to dry out. These can be greased through the sensor hole with an oversie zerk pressed in. They get noisy before they show any play. Are you replacing a bearing to get rid of an ABS problem? Sounds like a bad idea.
Old Jan 8, 2004 | 02:18 PM
norcalcapri
no, im replacing it because the hub is bad and now rattles, the abs light has been on since i got pulled out of the mud when i got stuck in the mud. which also cracked my steering rack, so i think that problem will be solved by doing this. i also have noticed a nice squeaking recently that slows down in pace as i slow down.
Old Jan 11, 2004 | 02:11 AM
norcalcapri
just got the new hub and it fixed the abs light, kragen matched and beat autozones price of $175, so i got it for $168, not too bad. thanks for your ideas.
-paul
tfdcapt
32
Jan 19, 2013 01:55 PM
cleevesj
Dec 5, 2008 03:57 PM
1979351M
Jul 16, 2007 03:30 PM
02FX4Dude
1983 - 2012 Ranger & B-Series
May 9, 2006 12:14 PM
TwoF150
18
Apr 24, 2003 07:54 AM
