Any one know if you can buy just the seals for the front hub assembly for the f-250 6.0 4x4? I have a good assembly but I need the inner seal. Will the dealer offer them?
Thanks!
I'm not sure they will offer it, but pretty sure they can order it for you.....
Look up the part # in the workshop manual.
If somehow the dealer won't be able to get it for you, check International also.
Oil seal (big seal): F81Z 3254CB
Front hub seal (small black seal) : F81Z 1S175HCA
ESOF seal (yellow o-ring on the back of the wheel hub): F81Z 4A322AA
Monster,
I looked up the Oil seal F81Z 3254CB and that does not look like the one I am looking for. The seal I need is the first seal you come to when disassembling the hub. When you take the slotted nut off the back of the hub, there is a dust shield and then the seal. It is copper in color. I have picture of it with the sizes in inches and metric.It looks like I can not post the pic but will put it in my gallery pics.
cleeves, it looks like you pulled the hub assy itself apart and meed an internal seal. not sure ford would be able to get that, i think ford outsources the hub assy. google sixstates. when i was in utah they were the people that we went to for hard to find stuff.
Check the seal for numbers - there is a chance that you could order the seal itself from Napa or some other parts house that can look up seal part numbers directly.
