Sponsored by: Auxito
Driver's side window
Old Jan 7, 2004 | 02:14 PM
97 blackbeauty's Avatar
97 blackbeauty
Question Driver's side window
I bought a '97 F-150 last march, 2WD 4.6 liter with 68,000 miles on it. There is couple of problems with it. When I first got it the passenger window went down but would not go back up until I fooled around with the switch for about 10 minutes. So after a couple of times of this happening I took the switch out and tried to clean the contacts and all. Now the passenger window works fine but the drivers window won't go down when the truck is cold or if it's cold outside. Can anyone help me with this. It is a real pain in the butt especially when I want to go through a drive thru or something. Thanks!!
Old Jan 7, 2004 | 09:08 PM
Racerguy's Avatar
Racerguy
Hi 97 blackbeauty and welcome to FTE
I think I'd start by replacing the switch. Most dealers stock them.
I would also take some silicone lube spray and lube the windows tracks at the front and rear of both windows.
Old Jan 8, 2004 | 06:28 AM
97 blackbeauty
Thanks for the welcome! I think I'll try the switch. I didn't know if maybe it could be something else with the wiring that was a common occurence with these trucks. Thanks again
sauce216
Mar 22, 2013 04:05 PM
bakerbuilttracks
20
Aug 6, 2011 05:20 PM
gmbtowing
2004 - 2008 F150
Sep 7, 2009 01:29 PM
Justin97
1997 - 2003 F150
Jul 16, 2007 03:22 AM
Penton97F150
1997 - 2003 F150
Oct 27, 2004 10:56 AM
