Modular V10 (6.8l)
superchip programming
Old Jan 6, 2004 | 05:04 PM
boxcar1974's Avatar
boxcar1974
I am thinking about buying the superchip programmer. How are these products to operate? Are there good instructions? Do you need abundant knowledge about engines and transmission to use this product? And is the system worth it? I just need some more information before I can pull that $300+ trigger. Hey....where is the chip located in the vehicle? Sound like a silly question but are they easy to access?
Old Jan 6, 2004 | 07:17 PM
Smokin_Superduty's Avatar
Smokin_Superduty
I have Superchip c h i p, I am satisfied with the increase in performance. The chip plugs into an access port in the vehicles computer. This computer is located on the drivers side, under the dash, in the corner, between the firewall and the footwell. It is a bit of PIA to remove the computer and install the chip.
The Superchip programmer that you seek is far easier to install then the chip. The programmer plugs into the diagnostics port. I believe this port is located under the dash, to the right of the steering wheel.
The main difference between the programmer and the chip is that; with the programmer you can tweek settings ( speed limiter, shift points, etc.) the chip needs to be removed and "reburned" to update.
Boxcar, I am no expert on this topic. If you want professional advice, check out the "Computer Chips and Tuners" Forum or click on the "Parts Shop" Link. The administrator of this website, Ken sells the Superchip brand and is a very knowledgable source of information.
socalpsdowner08
Computer Chips & Tuners
May 28, 2010 08:26 AM
maxtruck00
Feb 7, 2010 11:15 PM
EVB
Jul 23, 2007 05:32 PM
96ford4x4turbodiesel
Bio-diesel, Propane & Alternative Diesel Engine Fuels
27
Mar 10, 2004 01:05 AM
