Dome Light Wiring?
Old Jan 3, 2004 | 12:03 PM
Truckboy's Avatar
Truckboy
Dome Light Wiring?
My dome light did not work when I bought the truck just a few weeks ago, and I just tried a new bulb last night. Well it did not work. I guess it might be the wiring. I have not tried to see if I am getting any power through the wiring but whether I do or not, does anyone know where the wiring for that light runs? Do I take out the headliner to trace it or does it run down a post to the floor somewhere?
Old Jan 3, 2004 | 12:08 PM
jds1971's Avatar
jds1971
Before you start pulling the headliner,(which is a pain in my opinion) check your fuses. I believe the one that powers the cig. lighter is the same one that runs the dome light. If the fuse is good, check the door switches by jumping across one to see if the light comes on.
Joe
Old Jan 3, 2004 | 12:48 PM
Mil1ion's Avatar
Mil1ion
It runs from behind the instrument cluster on the left side , up through the driver's door pillar then across to the light.
It should be a green/yellow wire,.
Old Jan 6, 2004 | 12:47 PM
Truckboy's Avatar
Truckboy
Thanks Guys! I will check out the fuse first and then start on the wiring.
AndeyHall
Feb 20, 2018 08:03 PM
centralNH
Apr 9, 2014 09:18 AM
Bluey Zedoff
Nov 21, 2013 12:11 AM
Andrew010
6.7L Power Stroke Diesel
Sep 12, 2012 07:51 PM
ehockey2000
1978 - 1996 Big Bronco
Mar 30, 2011 08:54 PM
