04 expedition auto door locks
Bill
Close all the doors.
Confirm that the ignition switch is in the OFF position.
Turn the ignition switch from OFF to RUN.
NOTE: Steps 4 through 8 must be carried out within 30 seconds.
Press the power door lock UNLOCK button three times.
Turn the ignition switch from RUN to OFF.
Verify that the horn chirps. This indicates the system is in the enable/disable mode is ready to accept program changes.
Press the power door lock UNLOCK button one time to toggle the autolock/relock feature OFF.
Press the power door lock LOCK button once to enter the command.
Verify that the horn chirps one time. There should only be one chirp indicating that autolock/relock feature has been disabled. If one chirp is heard, followed by a longer sound of the horn, the autolock/relock feature has just been enabled. Return to Step 9.
Turn the ignition switch to the OFF position to exit the enable/disable mode.
Exit the vehicle and verify that the horn chirps once to indicate that a feature has been changed and that autolock/relock has been disabled.
Move the seat, rear view mirrors, and adjustable pedals to the desired position.
Press the memory set switch SET button.
Within five seconds, press any button on the remote transmitter, except the PANIC button and then press the appropriate memory set switch button.
Repeat Steps 1-3 for each remote transmitter to be programmed.
Keyless Entry Keypad Code Programming
Enter the permanent factory keyless entry keypad code.
Press the 1/2 button within five seconds to activate the programming mode. Holding the 1/2 button for more than two seconds after activation will erase the stored customer code. The door locks will lock, then unlock, confirming the code is erased. The existing code will not need to be erased to program new a code.
Within five seconds, enter the new five-digit keyless entry keypad code. The door locks will lock and unlock to confirm the new code is programmed.
