Keyless Entry
Old Sep 15, 2010 | 03:56 PM
97e150vanman's Avatar
97e150vanman
Keyless Entry
I have a 2006 E-150 with a keyless entry system. Both key fobs quit. I installed new battries and did the reprogram cycle. The locks work with the door switchs. The truck did go into the program mode (doors locked and unlocked). The system never responded to either key fob. I understand the keyless system has a antenna, could the connection have come off?. Where do I look for the system?
Old Sep 16, 2010 | 05:14 AM
JWA's Avatar
JWA
Can't speak for the '06's but my '97 E250 had the illuminated entry and such in an enclosure located just behind the drivers seat on the body side--two larger wire harnesses entering the B pillar post which eventually ran under the left side footwell step where it then connected to chassis wiring near the emergency brake pedal.
Perhaps a connection has failed but knowing some of these features there'll be a module or other assembly probably gone wrong.
HTH!
J W
Old Sep 19, 2010 | 10:03 AM
97e150vanman
I have a cargo van and there is no box behind the drivers seat. I will keep looking.
flamingx
1997 - 2003 F150
Apr 30, 2013 06:03 PM
ssaa426cuda
Oct 18, 2010 10:51 AM
ScubaCowboy
1997 - 2003 F150
Jul 1, 2003 01:29 AM
COLTOPDOG
1997 - 2003 F150
Mar 6, 2003 02:59 PM
