Does anyone know what the puller for the power steering looks like? I have to R&R the pump but you need to pull the pully which is plastic (cant use a gear puller), the center section looks like its where it goes but a battery term puller isn't strong enough, but it is the right size.
Rockledge, thanks but these will not work on the pump pulley. I wish they would but there is no place to put the bolts and the pulley itself is plastic, I chipped a piece as it is.
This picture from the same source shows the tool to install it. The manuals states in both cases, the tools should be "readily available at local auto supply stores".
Many years ago (1980's)they cost 75$ apiece, I know I own a set. They were bought for me by an A/C shop I used to work for that has since gone out of business, so they became mine.
They are a "MUST" to R&R the pulley, since it is pressed on.
Thanks guys appreciate it. I tried to use a 2 jaw puller but it didn't even budge. Will check autozone in the AM and if they dont have just take to a shop to see if they will pop off put on.
