1978 - 1996 Big Bronco
89 Bronco check engine light
Old Feb 25, 2003 | 12:28 PM
Kallie's Avatar
Kallie
Question 89 Bronco check engine light
I just traded my 92 Ranger do to needing more space for a 89 Bronco 4x4 it has 135000 miles and seems to run well. Well I took a piece of velcro off the instument panel to find the check engine light flashing intermintantly. I immediatly check the oil and it was 1/2 quart low, put more in and the light is still flashing. I have been told don't worry to much as long as it has oil and water. And to just remove the light bulb. It is just a small useless oxygen sensor. Well I didn't like that advice and I have been posting question and information on The Ranger forums for quite some time and tehy always wee helpful and when My son needed info for his 86 Bronco you helped me than so here I am. I has been harped on and jumped from what I found out from some other local person.I founf that our after the trade ofcourse. The tires also bind up when I turn to the right. It has 31's on it and is stock.
Thank you in advance,
Kallie
Old Feb 25, 2003 | 12:31 PM
msuforeman's Avatar
msuforeman
I don't understand what your asking. Please type a little slower in complete sentences or be a little more specific.
Thanks,
Brian
Old Feb 25, 2003 | 12:33 PM
tim330i's Avatar
tim330i
Try pulling the engine codes to figure out what the check engine light it from
http://www.broncodata.com/tech/codes.htm
At least check to see what it wrong, it could be something very simple.
Not sure about the tires, someone else can help you with that I am sure.
Tim
Old Feb 25, 2003 | 12:53 PM
Kallie's Avatar
Kallie
What I am asking is what could be causing the check engine light to be on? I have check the oil and water and all the levels are good.
I do not know how to check codes either. Could you please tell what I need and how to do it? I am very capable with the right information.
Thank you,
Kallie
Old Feb 25, 2003 | 01:20 PM
msuforeman's Avatar
msuforeman
Do the tires bind all the time when turning right? It doesn't happen after it's taken out of 4wd does it? As for the codes, my local Autozone will get the codes for free--Maybe yours will do the same. If not check out broncodata.com.
Brian
Old Feb 25, 2003 | 01:21 PM
tim330i's Avatar
tim330i
There a ton of things that could be causing your check engine light to be on. Did you click on that link that I posted? It tells you how to check your codes and has a code list so you know what the code means.
Tim
Old Feb 25, 2003 | 01:57 PM
yosemite's Avatar
yosemite
Autozone won't pull codes for an 89 Bronco.
This site tells you how to read the codes and give a list of what the numbers mean.
You have to use a "jumper"... wire or something. The "jumper" i use is a paper clip.
http://www.off-road.com/ford/bigbron...eec/index.html
Old Feb 25, 2003 | 02:06 PM
msuforeman's Avatar
msuforeman
Thumbs up 89 Bronco check engine light
I wonder why they'll pull codes for a 95 bronco and not a 89. What do they have against 89's.
Old Feb 25, 2003 | 03:21 PM
yosemite's Avatar
yosemite
i have an 88 and they said no. 92 is first year I think. ask them though, it may have just been the one I went to.
Old Feb 25, 2003 | 03:59 PM
JBronco's Avatar
JBronco
I think it's funny how the previous person "fixed" it by putting velcro over the light!
Old Feb 25, 2003 | 04:21 PM
steve83's Avatar
steve83
They've stopped supporting all systems before OBD-II because it's the first one that's standardized across ALL manufacturers. Older systems are not only different from one mfr. to another, but even one model to another, so it requires specific equipment and knowledge that you just can't afford at the prices they charge for Taiwanese parts.
Fortunately, it's easy to pull codes from a Ford.
Kallie
Electrical Systems/Wiring
Apr 30, 2011 04:28 PM
Kallie
Jul 27, 2009 11:28 AM
Kallie
15
Oct 21, 2006 06:23 PM
Kallie
Jan 3, 2004 01:45 AM
Kallie
1983 - 2012 Ranger & B-Series
Jan 20, 2002 08:08 PM
