T18 to C6 tranny swap 1986 F150
I am thinking about swapping out my T18 tranny for a C6 tranny. I have access to a rebuilt 4wd C6 transmission. My main question is if the transmission cross members are the same? If not can you use the orginal cross member I have in my truck.
Thanks,
Chris Aunchman
Thanks,
Chris Aunchman
That is good news to hear. I am going to probably pull everything out the front cause I am putting on new fenders and radiator support. I hear you about the T-case bolts, I remeber moving mine without the body lift installed, I was glad I had a nice set of Gear Wrenches!!! What type of shifter are you going with? Are you going togo with a floor like a Lokar style or Hurst? Or are you going to go with the column shifter? I was thinking of using one of the Hurst Univeral ones they have a nice long handle for the trucks.
Later
Chris
Later
Chris
windyhill
26
11-13-2010 06:20 PM
aunchman
09-24-2003 08:00 PM
aunchman
08-03-2003 11:39 AM
aunchman
08-05-2002 04:55 PM
