keypad entry
Old Dec 26, 2003 | 10:30 AM
will2004's Avatar
will2004
keypad entry
new to dis forum but i need help on locating the keypad number for my navigator 2001, can anyone help me on locating the number key.
Old Dec 26, 2003 | 11:07 AM
MisterCMK's Avatar
MisterCMK
Welcome to FTE!! It should be on a black module under the drivers dash. There will be a black module with a white sticker on it. The number will be on the sticker.
Old Dec 26, 2003 | 11:24 AM
will2004's Avatar
will2004
THANKS FOR THE INFORMATION I WILL CHECK IT OUT, WHAT ABOUT IF THE CODE HAS BEEN CHANGE HOW CAN I FIND OUT THE NEW ON OR WHAT CAN I DO.
Old Dec 26, 2003 | 11:27 AM
PaulC's Avatar
PaulC
The original code can't be removed, barring a hardware change. However, a supplemental code can be added.
Old Dec 26, 2003 | 11:31 AM
will2004's Avatar
will2004
OKAY SO IF THE PERSON THAT HAD THE VEHICLE AT FIRST ADDEDED A SUPPLEMENTAL CODE HOW CAN I OVERIDE THAT
Old Dec 26, 2003 | 12:21 PM
MisterCMK's Avatar
MisterCMK
To override the supplemental code, you would have to take it into the dealer and have them erase it. Also, when you type in all caps, it is like yelling.
Old Dec 26, 2003 | 03:01 PM
pounder90's Avatar
pounder90
You can program your own code in. The procedure is explained in the owner's manual. Enter the code from under the dash followed by (1-2) I think, double check that. Then enter your new code. It needs to have the same amount of digits as the factory code. If that doesn't work post a reply and I will post the procedure out of the manual if you don't have one. That should override the previous owner's code.
pw1981
Apr 4, 2011 06:49 PM
Wardog686
Jun 6, 2010 07:50 AM
scooterman320
Feb 11, 2005 06:03 AM
DIFFMASTER
1997 - 2003 F150
Jul 4, 2002 05:19 PM
Ford 4 Life
Mar 12, 2002 05:05 PM
