Corner bulbs
Old Dec 24, 2003 | 06:01 PM
Zinfinity's Avatar
Zinfinity
Corner bulbs
How the heck do you change the bulbs in the marker lamps beside the headlights? I cant seen to get in there at all.
Thanks for the help!!
Merry Christmas!!!
Old Dec 24, 2003 | 10:53 PM
matt_302's Avatar
matt_302
You need arms the size of toothpics just about. If you cant get it try taking off the front lense, or the other option is to take stuff in the way out when you get to that rotate the bulb assy. and pull er out the hardest part for me was placing the bulb back in the socket.
Old Dec 27, 2003 | 10:51 PM
Zinfinity's Avatar
Zinfinity
Does anyone else have any thaughts, cause i dont have toothpick sized arms, lol. There must be a way to get in
there....................right?
Old Dec 27, 2003 | 11:28 PM
acerockola77's Avatar
acerockola77
You can always do it this way...
Old Dec 28, 2003 | 07:56 AM
T/A Man's Avatar
T/A Man
Acerockola a big thank you on that link with the pics I will be changing a corner light today and was not quite sure were the mounting nuts were. I had attempted this last weekend and I could not find those nuts so I had thought that with the two top screws out that the lower half was held in with a male/female snap fitting well I was wrong and ended up cracking the chrome trim on the corner light what a bummer. Your info has shown me the way thank you....
Old Dec 29, 2003 | 12:10 AM
Zinfinity's Avatar
Zinfinity
Wow, thanks for the link!! Now i will be able to FINALLY put new bulbs in!!
Old Jan 24, 2004 | 12:39 PM
shakyhiway's Avatar
shakyhiway
i need to replace a corner light too but cant seem to pull up the link everybody else is seeing.is this private info or is my computer a piece of junk? could realy use the info.
Old Jan 24, 2004 | 01:06 PM
acerockola77
For some reason it's not workin for me either now. Looks like their site is down.
Old Jan 24, 2004 | 11:34 PM
SoCalDesertRider's Avatar
SoCalDesertRider
not working for me iether
Old Jan 24, 2004 | 11:43 PM
Moose F150 4x4's Avatar
Moose F150 4x4
it's easier this way
I managed to change my corner bulb by just taking out my coolant/ windsheild washer reservoir by removing the one 7/16th nut and sliding it out and over and then using a pair of needlenose pliers turning it counterclock wise and it came right out, to reinstall just reverse the process
jc8825
Aug 8, 2010 07:38 PM
mattpowerstroker
Feb 5, 2010 05:38 PM
topdrive
Dec 7, 2009 03:38 PM
oggjay
Dec 26, 2004 10:31 AM
markmac
1997 - 2003 F150
Jan 13, 2001 08:51 PM
