300 to 302 help...
what will i have to change on the engine?
im figuring the intake and dizzy (i have a 2bbl intake off a 85 302 will it work?),
im going to need a fuel pump right since the efi pump was in the tank and the truck is on the 300 ya? would a inline like a holly "Blue" work? if so what should it be regulated to? or would that depend on the carb i used?
i have been told that the trans will bolt right up ya?
are the mounts the same or will they have to be move/fabed?
will a MDS 6AL and a 8579(small diamiter pro-billit) MDS distro work on there own or will it need to have some sort of the ford ignition system too? guess im askin if its "stand alone"
i think i have missed a few but this will get me started
Thanks all
ok looking for a little info the truck is a 85' f150,2wd, with a 300, carbed, duraspark II ignited, 4spd (1,2,3,OD) Manual, 200K Km's, im looking to swap in a 88 or 89(forget the year) 302 from a buddys crown vic. My question's are:
You will need a duraspark II 302 specific distributor
There is an intank an inline pump on pre 90/87 or so, so you can get away with just unhooking the inline pump, or so I am told, or do it your way and unhook them both. (holley inline)
As long as you use the correct 302 flexplate/flywheel.
NO. You will need to get the engine mounting pads/ bracket off a 302/351 truck
yes, don't forget the coil. later
Thanks all
im lost on your description of the fuel pump system?
ok
car has in tank pump (88/89 efi)
truck has engine mounted mech pump(85 carbed)
so on the truck i should be able to just put a inline pump (and regulator if needed)like the holly and be good to go?
fuel PSI at the carb? depends on the carb or is it standardized?
lol ya won't forget the coil
thanks
Joe
www.summitracing.com www.jegs.com Carter has a 5psi electric pump, (no regulator required) $57.25 U.S.
www.jcw.com Jcwhitney has a few (no regulator required) for $40 +/- U.S.
Or your right a holley and adjustable fuel pressure regulator would work. I thought you had a efi 300 when I wrote my reply, sorry, you did write "...with a 300, carbed,..". Sorry for the confusion
the 85 carb is probably a feedback carb and if it not hooked up to the computer it won't work right
what im after is to lose all the "computer" crap in the swap i dont mind the MDS stuff due to the advantages it has.
went looking last night and the 2v intake was MIA so i guess im buying one so its going to be a 4v DP
like the edelbrock (EDL-2121) (non-EGR, idle-5500rpm, cast aluminum) and a edelbrock 500cfm carb to top it off (EDL-1404)
my main worie about the fuel pump is reliability
hope the carter pumps are better then the carter single barrel carb thats on the 300 lol its always messing up it seems
thanks again all
Joe
Merry Christmas!
Back to the water pump, If you do not have the serp setup for the 302, you will have to collect the following:
Pulleys: single groove PS, double groove water pump, double groove crank, single groove ALT, and single groove AC.
Brackets: Find a setup for a 85 1/2 or older Ford car( or truck) with a 302 or 289 with the alternator on the passengers side, and the PS on the lower drivers side.
Timing cover: You will need a timing cover from a 85 or older CARBED 302. These are standard rotation waterpump compatible. The EFI covers are not. This will solve the fuel pump issue, as the carbed cover has the cutout for the mechanical fuel pump. (FYI, there is one year and one car that had a serp belt, reverse rotation WP, and a mechanical FP. An 85' Mustang GT w/5spd manual trans. A hard find, but was a ford part for one year. Automatic 5.0L 'stangs were full EFI. Manuals were still Carbed.) Summit makes a cover that accepts standard or reverse Water pumps, and has the FP cutout. $110 last I looked.
Water pump: You will need a standard rotation WP for this setup.
If you go with the mechanical FP setup, you will need to find and buy a fuel pump eccentric to fit the 302. EFI's did not come with them.
Hope this helps.
