VIN Number Analyser??
Hello & Welcome to FTE!
This is the only late model VIN# de-coder I know of on the net.
https://www.fleet.ford.com/maintenan...ls/default.asp
VIN: 1FTRX17L63NB38447
1-2-3 World Manufacturer Identifier
VIN Code: 1FT
Place Manufactured: unknown...(USA)
Make: unknown .............(Ford)
Body Type: unknown.............(Truck)
4 Restraint System Type or Brake Type and GVWR Class
(Trucks and Vans Only)
VIN Code: R
Brake System: unknown
GVWR Class: unknown
Restraint: unknown
GVWR Range: unknown
5-6-7Line, Series, Body Type
VIN Code: X17
Vehicle Line/Series (Optional Nameplate): unknown
Chassis Type: unknown
Body Type: unknown
Vehicle Type: unknown
8 Engine Type
VIN Code: L
Engine/Litre: unknown
Cylinders: unknown
Fuel: unknown
Manufacturer: unknown
Net Brake H.P.: unknown
9 Check Digit
VIN Code: 6
Check Digit: True
10 Model Year
VIN Code: 3
Model Year: 2003
11 Assembly Plant
VIN Code: N
Vehicle Assembly Plant Name: Location: unknown .....(Norfolk, VA)
12-17 Production Sequence Number
VIN Code: B38447
Production Sequence Number: B38447
1FTZX17W2WNC09867
Codes:
WB - 139 (wheelbase)
BK - B
INT Tr - MX
TP/PS - C/
R - 9
Axle - H-9
TR - U
SPR - PF
Thanks for any help.
VIN: 2FTRXI7L9WCB14542 1st-2nd-3rd Positions
VIN Code: 2FT
Make: unknown
Body Type: unknown
4th Position*
VIN Code: R
GVWR Class: unknown
Restraint: unknown
GVWR Range: unknown
5th-6th-7th Position*
VIN Code: XI7
Body Type: unknown
8th Position*
Engine Type
VIN Code: L
Cylinders: unknown
Fuel: unknown
9th Position
Check Digit
VIN Code: 9
Check Digit: True
10th Position
Model Year
VIN Code: W
Model Year: 1998
11th Position
Assembly Plant
VIN Code: C
12th-17th Position
VIN Code: B14542
Production Sequence Number: B14542
*Please Note:
This position code offers multiple values. In the case of multiple values, this VIN Lookup Utility will list all possible values.
1FT F E11 6 0 W H A00001
1. World Vehicle Manufacturer
1FM — Ford Motor Company, USA, multi-purpose vehicle
1FT — Ford Motor Company, USA, truck, completed vehicle
1FD — Ford Motor Company, USA, incomplete vehicle
1FC — Ford Motor Company, USA, basic (stripped) chassis
1FB — Ford Motor Company, USA, bus
1FF — Ford Motor Company, USA, motor vehicle equipment without engine/powertrain (Glider)
1MH — Mercury, USA, incomplete vehicle
2FM — Ford Motor Company, Canada, multi-purpose vehicle
2FT — Ford Motor Company, Canada, truck, completed vehicle
2FD — Ford Motor Company, Canada, incomplete vehicle
2FC — Ford Motor Company, Canada, basic (stripped) chassis
2FB — Ford Motor Company, Canada, bus
2FF — Ford Motor Company, Canada, motor vehicle equipment without engine/powertrain (Glider)
2MH — Mercury, Canada, incomplete vehicle
3FB — Ford Motor Company, Mexico, bus
3FC — Ford Motor Company, Mexico, basic (stripped) chassis
3FE — Ford Motor Company, Mexico, incomplete vehicle
3FM — Ford Motor Company, Mexico, multi-purpose vehicle
3FT — Ford Motor Company, Mexico, truck, completed vehicle
4M2 — Mercury, USA, multi-purpose vehicle
4M3 — Mercury, USA, incomplete vehicle
4M4 — Mercury, USA, truck, completed vehicle
2. Brake Type and Gross Vehicle Weight Rating (GVWR) (all vehicles with hydraulic brakes)
A — 0-3000 Pounds
B — 3,001-4,000 Pounds
C — 4,001-5,000 Pounds
D — 5,001-6,000 Pounds
E — 6,001-7,000 Pounds (may also be "R")
F — 7,001-8,000 Pounds
G — 8,001-8,500 Pounds
H — 8,501-9,000 Pounds
J — 9,001-10,000 Pounds
K — 10,001-14,000 Pounds
L — 14,001-16,000 Pounds
M — 16,001-19,500 Pounds
3. Vehicle Line, Series, Body Type
E11 — Econoline Club Wagon
E31 — Econoline Club Wagon (Heavy Duty)
S31 — Econoline Club Wagon (Super Club Wagon)
E14 — Econoline E-150 (Cargo Van)
E24 — Econoline E-250 (Cargo Van)
E27 — Econoline E-250 (Commercial Cutaway)
E29 — Econoline E-250 (Commercial Basic)
E30 — Econoline E-350 (RV Cutaway)
E34 — Econoline E-350 (Cargo Van)
E37 — Econoline E-350 (Commercial Cutaway)
E39 — Econoline E-350 (Commercial Basic)
S24 — Econoline E-250 (Super Van)
S34 — Econoline E-350 (Super Van)
E40 — E-Super Duty (RV Cutaway)
E47 — E-Super Duty (Commercial Cutaway)
F07 — F-150 Flareside, 4x2
X07 — F-150 (SuperCab) Flareside, 4x2
F08 — F-150 Flareside, 4x4
X08 — F-150 (SuperCab) Flareside, 4x4
F17 — F-150 Styleside, 4x2
X17 — F-150 (SuperCab) Styleside, 4x2
F18 — F-150 Styleside, 4x4
X18 — F-150 (SuperCab) Styleside, 4x4
F27 — F-250 Styleside, 4x2
X27 — F-250 (SuperCab) Styleside, 4x2
F28 — F-250 Styleside, 4x4
X28 — F-250 (SuperCab) Styleside, 4x4
U22 — Explorer (2-door), 4x2
U32 — Explorer (4-door), 4x2
U24 — Explorer (2-door), 4x4
U34 — Explorer (4-door), 4x4
U35 — Explorer (4-door), AWD
U52 — Mountaineer (4-door) 4x2
U54 — Mountaineer (4-door) 4x4
U55 — Mountaineer (4-door) AWD
R10 — Ranger 4x2
R11 — Ranger 4x4
R14 — Ranger 4x2 (2-door SuperCab)
R15 — Ranger 4x4 (2-door SuperCab)
R18 — Ranger 4x2 (4-door SuperCab)
R19 — Ranger 4x4 (4-door SuperCab)
4. Engine Type
A — 2.3L EFI, four cylinder (Ranger 1997 and older)
6 — 4.6L EFI-SOHC (Windsor), eight cylinder (Econoline, F-150, F-250)
W — 4.6L EFI-SOHC, eight cylinder (F-150, F-250)
L — 5.4L EFI-SOHC, eight cylinder (Econoline, F-150, F-250)
S — 6.8L EFI-SOHC, ten cylinder (Econoline)
F — 7.3L Turbo-Diesel, eight cylinder (Econoline)
2 — 4.2L EFI-OHV, six cylinder (Econoline, F-150, F-250)
Z — 5.4L SOHC, gaseous fuel prep, eight cylinder (Econoline, F-150, F-250)
M — 5.4L SOHC natural gas, eight cylinder (Econoline, F-150, F-250)
X — 4.0L EFI-OHV, six cylinder (Explorer, Ranger)
E — 4.0L EFI-SOHC, six cylinder (Explorer, Mountaineer)
P — 5.0L EFI, eight cylinder (Explorer/Mountaineer)
B — 2.5L OHV-DI diesel, four cylinder (Ranger)
C — 2.5L EFI-SOHC, four cylinder (Ranger)
U — 3.0L, six cylinder (Ranger)
5. Check Digit
This is a generated number.
6. Model Year
V — 1997
W — 1998
X — 1999
Y — 2000
1 — 2001
2 — 2002
7. Assembly Plant
L — Michigan Truck (Wayne, Michigan)
S — Allen Park (Allen Park, Michigan)
H — Lorain (Lorain, Ohio)
C — Ontario Truck (Oakville, Ontario)
E — Kentucky Truck (Jefferson County, Kentucky)
K — Kansas City (Claycomo, Missouri)
N — Norfolk (Norfolk, Virginia)
U — Louisville (Louisville, Kentucky)
Z — St. Louis (Hazlewood, Missouri)
P — Twin Cities (St. Paul, Minnesota)
T — Edison (Edison, New Jersey)
8. Production Sequence Number - this is an alphanumeric code for the vehicle build sequence. This is also the vehicle serial and warranty number.
A00001-E99999 — Ford Division
J00001-L99999 — Lincoln-Mercury Division
