Sponsored by: Auxito
Help quick, interior lights will not go out
Old Jun 13, 2003 | 09:05 PM
BarryBum's Avatar
BarryBum
Help quick!!!!!!!!! My interior lights on my 97 F 150 will not go out, I have slammed all the doors hundreds of times. Key is not in the switch and interior light switch is not on. Sometimes it acts like it is on a timer and other times it just will not go out, until I slam the doors countless times.
Help quick..........thanks
Update: I think I have narrowed it down to the drivers door, but where in the world is the switch that the door pushes when the door is closed?? It also shows the door ajar light when the interior lights are on.
Old Jun 13, 2003 | 11:09 PM
f150-az's Avatar
f150-az
it sounds like there is a problem with the switch in the door. As for the switch in the door itself, it is located in the doorjamb. I've tried to locate it myself on several occasions but have not been successful. I have not physically seen it, but it sounds like that is where your problem lies. Hope that helps
Old Jun 14, 2003 | 01:33 AM
Racerguy's Avatar
Racerguy
The switches are in the door latches, not in the door jambs.
Usually spraying LOTS of WD40 into the latches will clean the switches and they will work again. Just open the doors and start spraying into the latches then open and close the doors a few times.
Only use WD40 and not a grease type spray. WD40 cleans well where as other types of spray lube dont.
Old Jun 14, 2003 | 02:06 AM
f150-az's Avatar
f150-az
my bad, i guess i was totally wrong there with the location thing. Maybe i'll make sure i know what i'm talking about before i reply next time. sorry guys
Old Jun 14, 2003 | 09:05 AM
Racerguy's Avatar
Racerguy
It's ok
A lot of people dont know where they are because you cant see them unless you remove the door panel.
Old Jun 14, 2003 | 11:47 AM
BarryBum's Avatar
BarryBum
That fixed it..........I drowned the door latch switch with WD-40 and they work fine now, Thanks guys.......great advice!!!!!
Old Jul 3, 2003 | 12:36 PM
stevesinger's Avatar
stevesinger
Another thing to note here is that many folks still use white lithium grease on these latches. That just makes the micro switches worse. If that happens spray some lectra motive or brake kleen. Let it dry and then re spray the WD 40.
Old Jul 3, 2003 | 01:24 PM
JeremyH's Avatar
JeremyH
Are you saying to use the WD-40 as a grease? I hope not....because it isnt.
Old Jul 3, 2003 | 01:27 PM
BGreener's Avatar
BGreener
I've got the exact same problem with my truck. I got so agrivated I pulled the interior light fuse out.
I'll have to try the WD-40 trick.
Old Jul 3, 2003 | 03:02 PM
stevesinger
WD 40 is not a grease but it is a lubricant. If you try and use a true grease such as the white lithium it will gum up the micro switches and they will not work. If you spray liberally with WD 40 about 2 times a year you should not have any more difficulty.
Old Dec 27, 2003 | 07:58 AM
oldexplorer1991's Avatar
oldexplorer1991
The WD40 solution did the trick for me...
Old Dec 27, 2003 | 01:07 PM
Racerguy's Avatar
Racerguy
Hi oldexplorer1991 and welcome aboard
Old Dec 27, 2003 | 10:57 PM
chingao81375's Avatar
chingao81375
ive had my fuses pulled out for years because of that problem i m gonna try a little dw40!!! My passenger side always stays ajar for days when i open it!!
