I noticed something odd!!!!!!
Old Dec 21, 2003 | 09:56 PM
darkman's Avatar
darkman
I have been building a cab roller for my 57. As I was measuring the frame to make the cab mounts I noticed the hole in the front cab mount bracket on the passenger side is elongated and not from wear. The drivers side is just a round hole. Both the back mount holes are not elongated. Any one else notice this or have a bare frame to compare. There must be a good reason for this and maybe it has something to do with the assembly line procedure. Anyone have a idea?
Old Dec 21, 2003 | 10:19 PM
ferguson777's Avatar
ferguson777
Charles,
Nobody has replied because they're all out in their garages unbolting their cabs to check. 'cept Daryl "Butch 302" Stone - he's booking an appointment to have a professional lift off his cab.
Old Dec 21, 2003 | 10:41 PM
My58Ford's Avatar
My58Ford
I just checked mine, same thing!
I probably would not have noticed it until I read your post!
Old Dec 22, 2003 | 08:59 AM
58hotrod's Avatar
58hotrod
I noticed that last winter when I had the cab off my 58. I'm pretty sure it has to do with adjustment, but I'm still confused why they didn't do it on the front left one as well.
Old Dec 22, 2003 | 09:13 AM
darkman's Avatar
darkman
Never having seen the assembly line I can only conjecture two things.
1. That portion of the cab was lined up first and having the slot allowed them to work faster. After one was in the others would line up easier.
2. A variance in the front cab floor width.
At least I'm not the only one that saw it.
Old Dec 22, 2003 | 09:50 AM
4tl8ford's Avatar
4tl8ford
Charles
I think that may be an "Expansion Compensator".
It is designed for individuals like Ferggie, so that as they grow older the sides of the cab can be "Let Out" to match their ever expanding postirior.
Old Dec 22, 2003 | 10:13 AM
DS02F250's Avatar
DS02F250
Sounds like the days of old at Ford where they were still putting a round bolt in a square hole. Result: the inevitable Ford rattle. Probably designed that way back in the day to make assembly quicker and easier; for adjusting the cab onto the frame during assembly; or all of the above.
Just my $.02
Daryl
1986F150six
Feb 13, 2015 10:59 AM
jerryst
19
Jan 1, 2013 09:34 PM
9905
Jul 16, 2012 01:21 AM
tip49
Jan 7, 2009 09:02 PM
rirwin
Mar 2, 2005 02:47 PM
