Carter YF identification, please!
Old Jul 25, 2011 | 12:43 PM
1986F150six's Avatar
1986F150six
I have aquired a Carter YF without the factory I.D. tag. The upper body is stamped YF4901S and it has the climatic choke [non electric]. The mounting holes are the older pattern [closer together] and have not been elongated.
Does someone know what the original application for this carburetor was? I know it was for a six cylinder, but what year and weight class?
Thanks!
Old Jul 25, 2011 | 01:11 PM
quaddriver's Avatar
quaddriver
choke heated from a tube in the manifold? is the dashpot mechanical or electric?
(I dont think you can tell weight class from the carb on the I6) BUT, the carter was NOT limited to the Ford engine! It was ANYWHERE that an I4 or 6 was used. (chevy, ford, amc, nash all come to mind)
wrong button....
anyways, the 4901 does have an xref to the 1970 van with the 240 I6
Old Jul 25, 2011 | 01:35 PM
1986F150six
Thank you, quaddriver. The choke is operated by hot air from the tube heated by the exhaust manifold.
Old Jul 25, 2011 | 02:33 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
That type of "climatic" choke was also used on the 1980's models, but with electric assist.
Does the carb have "autolite" anywhere stamped on it? That would narrow it down to a Ford engine before 1972...
Old Jul 25, 2011 | 03:01 PM
1986F150six
No sir, no "Autolite", just Carter YF and "Made in USA". It has one vacuum port, one hot idle screw and no fast idle adjustment other than adjusting the choke [lean vs rich].
Old Jul 25, 2011 | 05:51 PM
81-F-150-Explorer
If it was a Carter from a factory ford engine it would be stamped, Manufactured by Carter for Autolite, (later Motorcraft) Made in USA. etc...
Not saying your carter YF isn't for a Ford, it's just it would have narrowed it down to one auto company .
Old Feb 8, 2015 | 03:36 PM
chrlsful's Avatar
chrlsful
which YF
a pic would sure help
(40 yrs and a doz vehicles)
I seek the YF from the 300
to place on my 250...
any help?
I think it's same 2 bolt spacing...
it the bore the same?
Old Feb 8, 2015 | 07:11 PM
Gary Lewis's Avatar
Gary Lewis
Chad - This thread is 4 years dead.
Old Feb 13, 2015 | 10:59 AM
chrlsful's Avatar
chrlsful
Chad - This thread is 4 years dead.[/QUOTE]
(Got a recent post frm it to my box.)
But I'm not. Still seeking same & any info possible.
Thnx 4 ur post!
Muidem
Jun 17, 2011 12:16 PM
kadrocker
Feb 4, 2010 10:42 PM
Benztechnc
Feb 27, 2006 10:17 PM
BigBear1
May 24, 2004 11:56 AM
thedirtyneck
May 10, 2004 04:26 AM
