Compression
Old Dec 21, 2003 | 06:54 PM
There Goes The Neighborhood's Avatar
Compression
How about this. The motor in the race truck(473 cu. in. 460), after assembly, broke a 300 psi compression gauge!! Wondering what you guys have done. Compression figures right around 14.5:1, enough to warrant 114 octane race fuel.
Old Dec 25, 2003 | 01:40 AM
fordeverpower's Avatar
fordeverpower
damn that truck needs a serious starter.
Old Dec 25, 2003 | 12:41 PM
you ain't kiddin'. Stock starter lasted three times, and barely turned it over hot.
Old Dec 26, 2003 | 09:49 AM
airharley's Avatar
airharley
With 14.5 CR your only running 205 psi at the compression tester. Unless my math is just way off this morning. What are your #'s for the heads, pistons, gaskets, and so on?
Old Dec 26, 2003 | 08:48 PM
Heads 68 cc
pistons .060 over stock, have 1 valve relief, approximately 3cc
gasket 10.8cc
Zero deck clearance
3.85 stroke
enginebuilder5
Jun 10, 2016 05:21 AM
IsoGrifo
Oct 16, 2009 06:37 PM
reed1951
Jun 30, 2007 11:53 PM
smallblock351w
Feb 28, 2007 06:44 PM
71LTD390
Apr 22, 2004 08:17 PM
