Pump gas compression?
Old Jun 21, 2007 | 10:03 PM
reed1951's Avatar
reed1951
Question Pump gas compression?
What is the highest compression you can go before you have to start using race gas?
Old Jun 21, 2007 | 11:28 PM
Torque1st's Avatar
Torque1st
Posting Legend
There is no answer to that question. Look up DYNAMIC COMPRESSION RATIO at piston manufacturers sites or on the web. Even then combustion chamber shape, coatings, materials, surface finish, swirl. and squish/quench all make a difference.
Old Jun 23, 2007 | 06:34 AM
jade79's Avatar
jade79
I believe cam profile has an effect on that as well.
Old Jun 23, 2007 | 07:24 AM
phil6608's Avatar
phil6608
My truck is only 8.5-1 compression and my race tune that I have the timing way up I have to run C-16 race gas!
Old Jun 23, 2007 | 03:55 PM
Torque1st's Avatar
Torque1st
Posting Legend
Cam profile is a big part of what determines dynamic compression ratio.
Old Jun 24, 2007 | 03:53 AM
Red69's Avatar
Red69
I am running almost 11 to 1 on regular.
Old Jun 24, 2007 | 09:27 AM
petes79f150's Avatar
petes79f150
Red69, I would be interested to know how you are able to run 87? octane with almost 11:1, as I'm sure others would be also. I've run 11:1 with aluminum heads, a pretty radical cam, and careful tuning, but it required 97 octane to keep it out of detonation.
Let's say very interested.
Pete
Old Jun 24, 2007 | 02:41 PM
Red69's Avatar
Red69
I have a 1970 302 block. Centrifical advance Mallory Unilite at 6 dergrees BTC. Flat top .040 cast piston, 58cc heads millied .010 w/1.94/1.50 valves and port job. Cam is a .525/290 hydraulic. F4b Edlebrock intake with Holley 750 vacuum secondaries. I put a #55 power valve and #31 squirt nozzle in it. Headers with 2-1/4 exhaust and corvair turbo mufflers. T-10 4-speed and 4.10 posi.
The only time it ever pings is if you lug in 4th at 20 miles an hour or so. I have used octane boosters and different brands of premium fuel and can tell no difference.
Old Jun 24, 2007 | 06:18 PM
Torque1st's Avatar
Torque1st
Posting Legend
If you de-tune an engine by backing off on the timing and playing with the mixture as well as running real easy to turn gears you can run almost any compression. Of course mileage, power, and efficiency will suffer horribly.
Old Jun 27, 2007 | 07:50 PM
RacinNdrummin's Avatar
RacinNdrummin
If your running flat tops with 58cc heads milled .010, you dont have an 11:1 ratio, you would be lucky to have 10:1.
Old Jun 28, 2007 | 08:34 AM
Red69's Avatar
Red69
They were listed at 10:1 with a higher volume head. It was either 64 or 69cc. I can't remember.
Old Jun 28, 2007 | 04:40 PM
RacinNdrummin
The only way you can get 11:1 with 58cc chambers is with domed pistons or a stroker crank, flat tops wont do it.
Old Jun 30, 2007 | 11:53 PM
pud's Avatar
pud
Cylinder Head Volume (cc) 58cc
Piston Head Volume (cc) 0cc
Gasket Thickness (in.) 0.040"
Gasket Bore (in.) 4.06"
Cylinder Bore Diameter (in.) 4"
Deck Clearance (in.) 0.00"
Stroke (in.) 3.00"
STATIC COMPRESSION RATIO 10.295
I plugged those numbers in the KB-silvolite.com calculators and came up with that 10.3:1 ratio. Thats a zero decked block, that and the head gasket thickness made the most difference.
There are also claims about these "Singh" grooves that allow you to run high compression on 87 octane without a radical tune. Cruise through this thread if youre intruiged and follow the links https://www.ford-trucks.com/forums/2...ormance-3.html
HowieE
Aug 5, 2016 08:28 AM
Eric Kropp
Aug 10, 2014 03:56 PM
adamraaron
Oct 20, 2007 12:46 PM
gonefishin
17
May 1, 2003 11:51 PM
idahocrewcab
Sep 27, 2000 11:37 PM
